SnapCenter 5.0 cmdlets
Set-SmMaintenanceMode
Sets a host to maintenance or production mode.
Syntax
Set-SmMaintenanceMode [-HostNames]  <String>  [-MaintenanceStatus]  <SmMaintenanceStatus>
Detailed Description
Sets a host to maintenance or production mode. No scheduled jobs are executed for a host in maintenance mode.
Name Description Required? Pipeline Input Default Value
HostNames
The names of the hosts for which you want to change the maintenance mode.
true
true (ByPropertyName)
MaintenanceStatus
Specifies the maintenance status of the specified hosts. The maintenance status is Production or UnderMaintenance.
true
Example 1: Setting a host to production mode
 Set-SmMaintenanceMode -HostNames @("SQL_Host") -MaintenanceStatus Production
This example syntax sets the specified host to production mode.
Example 2: Setting multiple hosts to maintenance mode
 Set-SmMaintenanceMode -HostNames @("SQL_Host", "Verification_Host") -MaintenanceStatus UnderMaintenance
This example syntax sets the specified hosts to maintenance mode.
