Set-SmPolicy
Modifies an existing policy.
Syntax
Set-SmPolicy [-PolicyName] <String> [-PolicyType] <SmPolicyType> [-PluginPolicyType] <PluginCode> [-Description] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
PolicyName |
Specifies the policy you want to change. |
true |
true (ByPropertyName) |
PolicyType |
Specifies the policy type. Valid value is Backup. |
true |
PluginPolicyType |
Specifies the type of plug-in. You need to specify a plug-in type because policies are settings that are specific to one type of plug-in.Valid plug-in policies types are SCSQL, SCO and HANA. |
true |
Description |
Specifies an optional description of the policy. |
false |
UtmType |
Type of up to the minute (UTM) retention settings to apply to log backups. Possible values are days and count. |
false |
UtmCount |
Up to the minute (UTM) retention by count. |
false |
UtmDays |
Up to the minute (UTM) retention by days. |
false |
SqlBackupType |
SQL backup type. Possible values are LogBackup, FullBackup, and FullBackupAndLogBackup. |
true |
DatabasesPerGroup |
Maximum number of databases in a group. This is applicable only for full backup. |
false |
CopyOnlyBackup |
Determines whether the full backup is a copy only backup. |
false |
AGBackupType |
Availability Group backup type. Possible values are UsePreferredBackupReplica and UseSpecifiedBackupReplica. |
false |
AGBackupReplicaType |
Availability Group backup replica type. Possible values are Primary, Secondary, and All. |
false |
AGBackupPriorityMinimum |
Availability Group backup minimum priority. |
false |
AGBackupPriorityMaximum |
Availability Group backup maximum priority. |
false |
CreateLogFolderSnapshot |
Create Log folder Snapshot copy. |
false |
EnableLogFolderSnapshotRetention |
Enable Log folder Snapshot copy retention. |
false |
DeleteLogFolderSnapshotInExcess |
Delete log folder Snapshot copies in excess of specified count. If other options are specified, then that will be ignored and only the log snapshot retention value will get modified. |
false |
DeleteLogFolderSnapshotOlderThan |
Delete log folder Snapshot copies that are older than specified days. |
false |
VerifyLogBackup |
Enable log backup verification after backup. |
false |
DBCC_NOINDEX |
DBCC options NOINDEX. |
false |
false |
DBCC_ALL_ERRORMSGS |
DBCC options ALL_ERRORMSGS. |
false |
DBCC_NO_INFOMSGS |
DBCC options NO_INFOMSGS. |
false |
DBCC_TABLOCK |
DBCC options TABLOCK. |
false |
DBCC_PHYSICALONLY |
DBCC options PHYSICALONLY. |
false |
UpdateSnapMirrorAfterbackup |
Update SnapMirror copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type. |
false |
UpdateSnapVaultAfterbackup |
Update SnapVault copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type. |
false |
MirrorVaultUpdateRetryCount |
Number of retries to ensure SnapMirror or SnapVault update is triggered. |
false |
SnapVaultLabel |
Label for SnapVault copy. |
false |
AllowSavedStateBackup |
Allow saved state backup. |
false |
DeleteBackupInExcess |
Delete backup in excess of specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored. |
false |
DeleteBackupOlderThan |
Delete backups older than specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored. |
false |
PreScriptCommandVerification |
false |
PreScriptArgumentsVerification |
false |
PostScriptCommandVerification |
false |
PostScriptArgumentsVerification |
false |
ScriptTimeOutVerification |
false |
ScheduleType |
The schedule type. Possible values are None, Hourly, Weekly, Daily, and Monthly. |
false |
RetentionSettings |
Specifies in a hashtable the retention settings for the policy. |
false |
PreScriptCommand |
Prescript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names). |
false |
PreScriptArguments |
Specifies the prescript arguments. |
false |
PostScriptCommand |
Postscript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names). |
false |
PostScriptArguments |
Specifies the postscript arguments. |
false |
ScriptTimeOut |
Specifies script timeout value in seconds. |
false |
VerificationScheduleType |
Specifies when to run verification. |
false |
DeleteCloneOnScheduleExpiry |
Removes a clone during the last run of a scheduled job.If this parameter is not set, then the last run of a schedule also runs a clone life cycle and creates a cloned database.This parameter does not apply to jobs that are not scheduled or to one time job schedules. |
false |
BackupPolicyName |
Specifies the backup policy name. |
true |
CloneType |
Specifies the clone type. Possible values are Primary and Secondary. |
false |
VerifyOnSecondary |
Specifies whether to verify on Secondary or not. |
false |
false |
NumOfBackups |
Number of backups to be verified. |
false |
false |
PluginParams |
false |
DominoChangeInfoPath |
false |
DominoDatabaseType |
false |
DominoIniPath |
false |
DominoRestoreFilePath |
false |
DominoRestoreTime |
false |
Lotus |
false |
NotesExecDirectory |
false |
DominoDisableReplication |
false |
DominoIgnoreCorruptedDB |
false |
DBMCliCmd |
false |
HandleLogWriter |
false |
MaxDBBGServerPrefix |
false |
MaxDBUpdateHistLog |
false |
SQLCliCmd |
false |
XUserEnable |
false |
DB2Cmd |
false |
SybaseISQLCmd |
false |
SybaseManifest |
false |
SybaseManifestDelete |
false |
SybaseManifestFormat |
false |
SybaseTranDump |
false |
SybaseTranDumpCompress |
false |
SybaseTranDumpFormat |
false |
OracleBackupType |
Modifies the Oracle backup type. Type values are Online, Offline mount, and Offline shutdown. |
true |
OracleBackupScope |
Modifies the Oracle backup scope. This parameter is only valid when the backup type is Online. Backup scope values are Full, Data, and Log. |
true |
OracleSkipPDBSaveState |
Modifies the skip PDB save state. This parameter is only available when you select Offline shutdown backup type. Values are either True or False. |
false |
DeleteAllArchiveLogs |
Prunes (deletes) all archive logs after Full or Log backups. |
false |
DeleteArchiveLogsOlderThan |
Modifies the number of days before archive logs older than a specified number of days are pruned (deleted). This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour. |
false |
DeleteArchiveLogFromAllDestination |
Modifies whether archive logs are pruned on all destinations or only on backed up destinations. If the value is True, archive logs are pruned on all destinations. If the value is False, archive logs are pruned only on backed up destinations. |
false |
DeleteArchiveLogBackupInExcess |
Modifies the number of archive log backups deleted in excess of the specified backup count. |
false |
DeleteAchiveLogBackupOlderThan |
Modifies the number of archive log backups deleted that are older than the specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour. |
false |
CatalogBackupWithOracleRMAN |
false |
ScwBackupType |
Specifies the type of SnapCenter for Windows backup. Valid values are CrashConsistent and FilesystemConsistent. |
true |
SceBackupType |
Specifies the backup type you want SnapCenter for Microsoft Exchange Plug-in to use. |
true |
UtmCounts |
false |
BackupTruncatedTransactionLog |
false |
BackupActiveCopies |
false |
BackupCopiesOnServer |
false |
BackupType |
This is a SAP HANA database specific parameter. Specifies the type of SAP HANA backup. The possible values are FileBasedBackup and SnapshotBasedBackup. |
true |
Example 1: Modifying an existing Microsoft SQL policy
Set-SmPolicy -PolicyName test -PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackup -ScheduleType Hourly -DaysInterval 8 -StartTime $SystemTime -EndTime $SystemTimeExpire -SchedulerType SQL
This example syntax modifies an existing Microsoft SQL policy.
Example 2: Modifying an existing Oracle policy
Set-SmPolicy -PolicyName 1 -PolicyType Backup -PluginPolicyType SCO -OracleBackupType ONLINE -OracleBackupScope FULL -DeleteAllArchiveLogs $true -DeleteArchiveLogFromAllDestination $true -DeleteArchiveLogBackupInExcess 5
Modifies an existing Oracle policy.
Example 3: Modifying an existing Windows backup policy
Set-SmPolicy -PolicyName scw_policy3 -PolicyType Backup -PluginPolicyType SCW -ScwBackupType CrashConsistent
This example syntax modifies an existing Windows SCW policy.
Example 4: Modifying an existing SAP HANA backup policy of type SnapshotBasedBackup
Set-SmPolicy -PolicyName hana_snapshotbased -PolicyType Backup -PluginPolicyType HANA -BackupType SnapShotBasedBackup -UpdateSnapMirrorAfterbackup $true -UpdateSnapVaultAfterbackup $true -SnapVaultLabel slabel
This example syntax modifies an existing SAP HANA backup policy of type SnapshotBasedBackup.
Example 5: Modifying an existing Microsoft SQL policy with SnapLock Retention
Set-SmPolicy -PolicyName SCSQL_Snaplock_Policy -PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackupAndLogBackup -ScheduleType Daily -retentionsettings @{"BackupType"="DATA"; "ScheduleType"="DAILY";"RetentionDays"="16";"SnapLockRetentionPeriod"=16;"SnapLockRetentionPeriodType"="Days"},@{"BackupType"="LOG"; "ScheduleType"="DAILY";"RetentionCount"="9";"SnapLockRetentionPeriod"=16;"SnapLockRetentionPeriodType"="Days"}
INFO: Specifying a retention period prevents the Snapshot copies from being deleted until the SnapLock retention period expires. This could lead to retaining a larger number of Snapshot copies than the count specified in the policy.
ApplySnapvaultUpdate: False
ApplyRetention : True
RetentionCount : 0
RetentionDays : 16
ApplySnapMirrorUpdate : False
SnapVaultLabel :
MirrorVaultUpdateRetryCount : 3
Retentions : {, , }
LastBackupStatus:
LastBackupDate :
IncludeAcls :
AppPolicies : {}
Description :
PreScriptPath :
PreScriptArguments :
PostScriptPath :
PostScriptArguments :
ScriptTimeOut : 60
DateModified: 8/13/2023 6:56:10 PM
DateCreated : 8/13/2023 6:56:10 PM
Schedule: SMCoreContracts.SmSchedule
PolicyType : Backup
PluginPolicyType: SMSQL
InBuilt : False
Schedules : {}
AllowMultipleSchedules : False
Type:
Host:
UserName:
Passphrase :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
ResourceGroupNames :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject : SMCoreContracts.SmObjectSize
Retention Settings
BackupType : DATA
SchedulerType : Daily
RetentionCount : 0
RetentionDays : 16
VerificationEnabled : False
NodeName:
SnapLockRetentionPeriod : 16
SnapLockRetentionPeriodType : Days
BackupType : LOG
RetentionCount : 9
RetentionDays : 0
NodeName:
BackupType : LOG_SNAPSHOT
SchedulerType : None
RetentionCount : 2
RetentionDays : 0
NodeName:
Example 6: Modifying the Snapshot copy log retention
Set-SMPolicy -PolicyName 'Log_policy_1' -PolicyType 'Backup' -Description 'log backup Policy' -retentionsettings @{"BackupType"="DATA";"RetentionCount"="2"},@{"BackupType"="LOG";"RetentionCount"="2"},@{"BackupType"="LOG_SNAPSHOT";"RetentionCount"="3"} -pluginpolicytype 'SCSQL' -sqlbackuptype 'logbackup'
This example modifies the Snapshot copy log retention. When you change the retention setting, you must also specify the other cmdlet parameters, otherwise, the current settings will override the default settings.
Example 7: Modifying log snapshot copy retention value without resetting the other policy settings
Set-SmPolicy -PolicyName 'test' -PolicyType Backup -PluginPolicyType 'SCSQL' -DeleteLogFolderSnapshotInExcess 2 -SqlBackupType 'fullbackupandlogbackup'
This example modifies the log snapshot copy retention value. If other policy options are specified then these options will be ignored and only retention value will be modified.
