Uncatalog-SmBackupWithOracleRMAN
Uncatalog Oracle backup(s).
Syntax
Uncatalog-SmBackupWithOracleRMAN [-PluginCode] <PluginCode> [-BackupIds] <String> [-BackupNames] <String> [-AppObjectId] <String>
Detailed Description
Uncatalogs the Oracle Database backup(s) in SnapCenter with Oracle Recovery Manager (RMAN).
Name | Description | Required? | Pipeline Input | Default Value |
PluginCode |
Specifies the plug-in code of the resource to be cataloged. |
true |
false |
BackupIds |
Specifies the id of backup that need to be uncataloged. Multiple backup ids can be specified in a comma separated list. |
false |
false |
BackupNames |
Specifies the name of the backup that need to be uncataloged. Multiple backup names can be specified in a comma separated list. |
false |
false |
AppObjectId |
Specifies the ID of the application object. |
false |
true (ByPropertyName) |
Example 1: Uncataloging a SCO backup using backupId
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupId 7
This example syntax uncatalogs a SCO backup using backupId.
Name: Uncataloging Backup(s) scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_01.13.03.7681_1 Id : 48 StartTime : 8/7/2020 2:11:00 AM EndTime : IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : True IsScheduled : False PercentageCompleted : 0 Description : Status : Queued Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0 JobTypeId : 29 ApisJobKey : ObjectId: 0 PluginCode : SCO PluginName : SnapCenter Plug-in for Oracle Database HostId : 0 RoleId : JobIds : {}
Example 2: Uncataloging a SCO backup using backupname
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_04.13.23.4083_1
This example syntax uncatalogs a SCO backup using backupname.
Name: Uncataloging Backup(s) scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_04.13.23.4083_1 Id : 46 StartTime : 8/7/2020 2:05:40 AM EndTime : IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : True IsScheduled : False PercentageCompleted : 0 Description : Status : Queued Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0 JobTypeId : 29 ApisJobKey : ObjectId: 0 PluginCode : SCO PluginName : SnapCenter Plug-in for Oracle Database HostId : 0 RoleId : JobIds : {}
Example 3: Uncataloging a SCO backup for the desired database
Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName rg1_galaxy-vm134_08-08-2020_15.11.16.3564_0 -AppObjectId 'galaxy-vm134.gdl.englab.netapp.com\DB14'
This example syntax uncatalogs a SCO backup for the desired database.
Name: Uncataloging Backup(s) rg1_galaxy-vm134_08-08-2020_15.11.16.3564_1 Id : 50 StartTime : 8/7/2020 2:10:40 AM EndTime : IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : True IsScheduled : False PercentageCompleted : 0 Description : Status : Queued Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0 JobTypeId : 29 ApisJobKey : ObjectId: 0 PluginCode : SCO PluginName : SnapCenter Plug-in for Oracle Database HostId : 0 RoleId : JobIds : {}
