SnapCenter cmdlets
Uncatalog-SmBackupWithOracleRMAN
Uncatalog Oracle backup(s).
Syntax
Uncatalog-SmBackupWithOracleRMAN [-PluginCode]  <PluginCode>  [-BackupIds]  <String>  [-BackupNames]  <String>  [-AppObjectId]  <String>
Detailed Description
Uncatalogs the Oracle Database backup(s) in SnapCenter with Oracle Recovery Manager (RMAN).
Name Description Required? Pipeline Input Default Value
PluginCode
Specifies the plug-in code of the resource to be cataloged.
true
false
BackupIds
Specifies the id of backup that need to be uncataloged. Multiple backup ids can be specified in a comma separated list.
false
false
BackupNames
Specifies the name of the backup that need to be uncataloged. Multiple backup names can be specified in a comma separated list.
false
false
AppObjectId
Specifies the ID of the application object.
false
true (ByPropertyName)
Example 1: Uncataloging a SCO backup using backupId
 Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupId 7
This example syntax uncatalogs a SCO backup using backupId.
Name: Uncataloging Backup(s)
  scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_01.13.03.7681_1
StartTime   : 8/7/2020 2:11:00 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 29
ApisJobKey  :
ObjectId: 0
PluginCode  : SCO
PluginName  : SnapCenter Plug-in for Oracle Database
HostId  : 0
RoleId  :
JobIds  : {}
Example 2: Uncataloging a SCO backup using backupname
 Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName scspr1894465002_gdl_englab_netapp_com_TSPITRDB_scspr1894465002_08-06-2020_04.13.23.4083_1
This example syntax uncatalogs a SCO backup using backupname.
StartTime   : 8/7/2020 2:05:40 AM
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 29
ApisJobKey  :
ObjectId: 0
PluginCode  : SCO
HostId  : 0
RoleId  :
JobIds  : {}
Example 3: Uncataloging a SCO backup for the desired database
 Uncatalog-SmBackupWithOracleRMAN -PluginCode SCO -BackupName rg1_galaxy-vm134_08-08-2020_15.11.16.3564_0 -AppObjectId 'galaxy-vm134.gdl.englab.netapp.com\DB14'
This example syntax uncatalogs a SCO backup for the desired database.
  rg1_galaxy-vm134_08-08-2020_15.11.16.3564_1
StartTime   : 8/7/2020 2:10:40 AM
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 29
ApisJobKey  :
ObjectId: 0
PluginCode  : SCO
HostId  : 0
RoleId  :
JobIds  : {}
