SnapCenter cmdlets
Invoke-SmTechRefreshPrimaryStorage
Perform storage tech refresh of host.
Syntax
Invoke-SmTechRefreshPrimaryStorage [-HostName]  <String>  [-IsDryRun]  <Boolean>  [-ChangedNDVMapping]  <Hashtable[]>
Detailed Description
Name Description Required? Pipeline Input Default Value
HostName
Specify the host name on which storage refresh has to be done.
true
true (ByPropertyName)
IsDryRun
Specify whether you want to perform a dry run to find the list of resources for which storage has changed. By default, the value of dry run is set to true.
false
True
ChangedNDVMapping
Specify the list of Non Data Volumes(NDV) mapping if NDV resource is being migrated from one set of volumes to another set. You must provide the NDVs mapping in a hashtable, and it must contain the OldVolumePath and NewVolumePath. For example,@{"OldVolumePath"="SVM1:/vol/myVol1";"OldVolumePath"="SVM2:/vol/myVol1_new"},@{"OldVolumePath"="SVM3:/vol/myVol2";"OldVolumePath"="SVM4:/vol/myVol2_new"} You can include comma-separated values for multiple NDVs mapping.
false
Example 1: Storage tech refresh of host.
 Invoke-SmTechRefreshPrimaryStorage -HostName host.mva.gdl.netapp.com -IsDryRun 0
Initiating storage tech refresh..
Name: Tech refresh of storage in host 'host.mva.gdl.netapp.com'
StartTime   : 10/26/2023 5:02:14 AM
EndTime : 10/26/2023 5:02:14 AM
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 52
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
ScsJobId:
Invoke-SmTechRefreshPrimaryStorage Completed
This example does a tech refresh of the storage in the host.
Example 2: Storage tech refresh of host.
 Invoke-SmTechRefreshPrimaryStorage -HostName host.mva.gdl.netapp.com -IsDryRun 0 -ChangedNDVMapping @{"OldVolumePath"="SVM1:/vol/myVol1";"NewVolumePath"="SVM2:/vol/myVol1_new"},@{"OldVolumePath"="SVM3:/vol/myVol2";"NewVolumePath"="SVM4:/vol/myVol2_new"}
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 52
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
ScsJobId:
This example does a Tech refresh of storage in the host.
