SnapCenter cmdlets
Remove-SmUser
Removes AD users or local workgroup users from SnapCenter.
Syntax
Remove-SmUser [-UserName]  <SmString>  [-Domain]  <String>
Detailed Description
Removes Active Directory users or local workgroup users from SnapCenter.
Name Description Required? Pipeline Input Default Value
UserName
Single user or list of users belonging to the same domain or workgroup.
true
true (ByPropertyName)
Domain
The domain to which the user belongs to. Workgroup users should skip this parameter.
false
Example 1: Removing a single user 1
 Remove-SmUser -UserName user1 -Domain domain1
Example 2: Removing multiple users of same domainle 2
 Remove-SmUser -UserName user1,user2 -Domain domain1
Example 3: Removing workgroup user
 Remove-SmUser -UserName LocalUser1
