Rename-SmBackup
Renames an existing backup.
Syntax
Rename-SmBackup [-BackupName] <String> [-NewBackupName] <String> [-PluginType] <PluginCode>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
BackupName |
Name of the existing backup. |
true |
false |
NewBackupName |
The new name you will give the backup. |
true |
false |
PluginType |
Provides the SnapCenter plug-in type. You can specify one of the following: SCSQL or SCW. |
true |
false |
Example 1: Renames an existing backup
Rename-SmBackup -BackupName SQL_DATASET_CLONE_csmdev-smsql-02_08-03-2015_13.45.19.4400
-NewBackupName SQL_DATASET_CLONE_RENAMED -PluginType SCSQL -Verbose
This example command syntax renames an existing backup to a new name that you specify.
VERBOSE: Start Rename-SmBackup
VERBOSE: Rename-SmBackup ended successfully.
