Add-SdLunMap
Maps your LUN to an igroup.
Syntax
Add-SdLunMap [-StorageSystem] <String> [-LunPath] <String> [-Igroup] <String> [-Session] <String> [-Host] <String>
Detailed Description
Maps your LUN to an igroup. You can use this on the storage system level, for Data ONTAP storage systems. If you are performing provisioning operations, use New-SdStorage.
| Name | Description | Required? | Pipeline Input | Default Value |
StorageSystem |
Specifies the storage system on which the igroup to which you want to map your LUN is located. |
true |
true (ByPropertyName) |
LunPath |
Specifies the LUN on your storage system. |
true |
Igroup |
Specifies the igroup to which you want to map your LUN. |
true |
Session |
Specifies the session ID from Open-SmConnection. For internal use only. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Maping a LUN to an igroup on an ONTAP storage system
Add-SdLunMap -StorageSystem svm1 -LunPath /vol/vol1/lun1 -Igroup “myTestIgroup"
This example syntax maps the LUN called lun1 to the igroup"myTestIgroup" on svm1.
