Add-SmResourceGroup
Adds a resource group to SnapCenter.
Syntax
Add-SmResourceGroup [-ArchivedLocators] <Hashtable[]> [-ResourceGroupName] <String> [-BackupServers] <SmBackupServer> [-PluginCode] <PluginCode> [-EnableEmail] <> [-EmailPreference] <SmEmailNotificationPreference> [-isInternal] <Boolean>
Detailed Description
Creates a new resource group. You can specify policies, schedules, verification schedules, and resources to be associated with the resource group.
| Name | Description | Required? | Pipeline Input | Default Value |
ArchivedLocators |
Specifies in a hashtable the secondary storage system details for each unique primary storage system resource in the resource group. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"} |
false |
true (ByPropertyName) |
ResourceGroupName |
Specifies the name of the resource group that you want create. |
true |
BackupServers |
false |
PluginCode |
Specifies the plug-in code of the host for which you are creating a backup resource group. Valid values are SCSQL, SCW, and SCO. |
true |
EnableEmail |
Specifies whether to enable or disable email. |
false |
false |
EmailPreference |
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning. |
false |
false |
isInternal |
false |
Resources |
Specifies the list of resources to be associated with the resource group.You must provide the resource information in a hashtable, and it must contain the resource name and type, and the host on which it is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}For instance-level backup @{"Host"="localhost";"Type"="SQL Instance";"Names"="Instance"}For availability group backup @{"Host"="localhost";"Type"="SQL Availability Group";"Names"="AG1"}For custom plug-in @{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db1"}Valid Type values are: SQL Database, SQL Instance, SQL Availability Group.You can include comma-separated values for Names. For Oracle Database, the format is @{"Host"="host.example.com";"Oracle Database"="db1,db2,.."}. For Oracle Application Volume, the format is @{"Host"="host.example.com";"Application Volume"="appVol1,appVol2,.."}. |
true |
Description |
Specifies an optional description for the new resource group. |
false |
Tag |
Enables you to apply a unique tag to help identify the resource group. |
false |
Policies |
Specifies the list of policies associated with the resource group. Multiple policies can be added as a comma-separated list. |
false |
SchedulerCredentialName |
false |
SchedulerInstance |
Specifies the SQL Server Instance where the schedule is created and managed. This is mandatory if the policy has SQL scheduler enabled. |
false |
VerificationServers |
Specifies the list of verification servers to be associated with the resource group. Multiple verification servers can be added as a comma-separated list. This parameter is only required when you want to verify backups for SnapCenter Plug-in for Microsoft SQL Server resource groups. |
false |
CustomSnapshotFormat |
Specifies that you want to use a custom Snapshot copy naming format. By default, a timestamp is appended to the Snapshot copy name. Valid values for CustomSnapshotFormat are : $ResourceGroup, $Policy, $HostName, $ScheduleType, $CustomText |
false |
CustomText |
Specifies the custom text in the custom Snapshot copy naming format. |
false |
DeleteBackupForDetachPolicies |
false |
Schedules |
Specifies the schedule parameters to be used in the resource group. Schedule parameters can include the policy name, schedule type, schedule start and end times. You can specify multiple schedules in a comma-separated list, for example:-Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="05/27/2016 6:30 PM"} |
false |
SchedulerType |
Specifies the scheduler type. Possible values are Windows, SQL, None. |
false |
VerificationSchedules |
Specifies the verification schedules you want to add to the resource. The verification schedule includes the following parameters:"VerificationType" which defines if and when verification is performed. The following values are available:VERIFY_SCHEDULEDVERIFY_AFTER_BACKUPNONE"ScheduleType" represents the schedule type for the verification."BackupScheduleType" represents the schedule type for the backup-VerificationServers "WIN-DVGQDI73QR6" needs to be provided in the above command if we are creating verification enabled resource group for SCSQL plugin. |
false |
BackupArchiveLogsAfterRecentMissingOne |
This option is only valid for SCO plugin code. Specifies that you want to backup archive log files, which are created after the most recent missing archive log files and ignore the files created prior to it. If this option is not specified, then all archive log files except the missing archive log files are be backed up. |
false |
ExcludeArchiveLogPathsFromBackup |
This option is only valid for SCO plugin code. Specifies the archive log destinations to be excluded from backup. Archive log files present in the specified destinations will be excluded during log backup. Multiple entries can be specified using comma separated list. For example: -ExcludeArchiveLogPathsFromBackup '/arch/logs/on/local/disk1, /arch/logs/on/local/disk2'. |
false |
ConsistencyGroupSnapshot |
false |
ConsistencyGroupWaflSync |
false |
ConsistencyGroupTimeOut |
false |
SnapShotCreateCommand |
false |
UseFileSystemConsistentSnapshot |
Specifies that you want to use file system consistent Snapshot copy. |
false |
UseSnapcenterWithoutFileSystemConsistency |
false |
PreAppQuiesceCmd |
false |
PostAppQuiesceCmd |
false |
AppQuiesceCmd |
false |
AppUnQuiesceCmd |
false |
PreAppUnQuiesceCmd |
false |
PostAppUnQuiesceCmd |
false |
PreExitCmd |
false |
PreSnapshotCmd |
false |
PostSnapshotCmd |
false |
AppIgnoreError |
false |
UseExternalSnapShot |
false |
ExternalSnapshotRegex |
false |
ConfigParams |
false |
EmailBody |
Specifies the body of the email. |
false |
EmailFrom |
Specifies the sender's email address. |
true |
EmailTo |
Specifies the recipient's email address. |
true |
EmailSubject |
Specifies the subject of the email. |
true |
EnableEmailAttachment |
false |
Example 1: Creating a new resource group
Add-SmResourceGroup -ResourceGroupName DS26 -PluginCode SMSQL -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"}
-Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin
-Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"}
-SchedulerType Windows
This example syntax creates a new resource group.
Example 2: Adding a resource group for custom plugin with consistency group Snapshot copy enabled
Add-SmResourceGroup -ResourceGroupName 'ResourceGroup_with_CG' -Resources @(@{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db1"},@{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db2"}) -Policies primaryonly -consistencygroupsnapshot 1 -usesnapcenterwithoutfilesystemconsistency -plugincode 'DB2'
This example syntax creates a resource group of two DB2 databases with Consistency Group Snapshot copies enabled.
Example 3: Creating a resource group with scheduled verification
Add-SmResourceGroup -ResourceGroupName DS26 -PluginCode SMSQL -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"} -Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"} -SchedulerType Windows -VerificationSchedules @{"BackupScheduleType"="Hourly";"DeferredBackupCount"="1";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="true";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Monday";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM"},@{"BackupScheduleType"="Daily";"DeferredBackupCount"="2";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="false";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Monthly";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM";"MonthofTheYear"="March";"DaysoftheMonth"="15"} -ArchivedLocators @{Primary="test_vserver:vol_ash_test";Secondary="test_vserver:test_vserver_vol_ash_test_vault"}
This example syntax creates a new resource group with verification.
Example 4: Creating a resource group with scheduled verification and verification after backup
Add-SmResourceGroup -ResourceGroupName RG27 -PluginCode SCO -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Oracle Database"="newdb"} -Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Sunday"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Monthly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="05/27/2016 6:30 PM";"MonthsofTheYear"="March";"DaysoftheMonth"="2"} -SchedulerType Windows -VerificationSchedules @{"BackupScheduleType"="Weekly";"DeferredBackupCount"="1";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="true";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Monday";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM"},@{"BackupScheduleType"="Monthly";"DeferredBackupCount"="2";"VerificationType"="VERIFY_AFTER_BACKUP";"VerifyOnSecondary"="false";"BackupPolicyName"="BackupPolicy"}
This example syntax creates a new resource group with scheduled verification and verification after backup.
Example 5: Adding an Always On availability group
Add-SmResourceGroup -ResourceGroupName AG_Prod -Resources @{"Host"="myag1";"Type"="SQL Availability Group";"Names"="AG_Prod"} -PluginCode SMSQL -Policies "SQL Daily Full" -Schedules @{"PolicyName"="SQL Daily Full";"ScheduleType"="Daily";"StartTime"="10/28/2017 6:13 PM";"EndTime"=""} -schedulerType SQL -SchedulerInstance SQL1
This example syntax adds an Always On availability group named AG_Prod to a SnapCenter resource group.
Example 6: Adding a resource group for HANA plugin
Add-SmResourceGroup -ResourceGroupName '43RG57' -Resources @{"Host"="schana02.gdl.englab.netapp.com";"Uid"="MDC\R57"} -plugincode 'hana' -Policies 'HANAPOLICY'
This example adds a resource group for HANA plug-in.
Tag :
ByPassRunAs : False
Configuration : SMCoreContracts.SmConfiguration
CreationTime: 02-Oct-19 21:38:06
CustomSnapshotFormat:
CustomText :
Description :
EmailBody :
EmailFrom :
EmailNotificationPreference :
EmailSMTPServer :
EmailSubject:
EmailTo :
EnableAsupOnFailure :
EnableEmail :
EnableSysLog:
HostResourceMaping : {}
IsCustomSnapshot:
LastBackupStatus:
MaintenanceStatus : Production
ModificationTime: 02-Oct-19 21:38:06
PluginProtectionGroupTypes : {hana}
Policies: {}
ProtectionGroupType : Backup
SchedulerSQLInstance:
SearchResources : False
VerificationServer :
VerificationServerInfo : SMCoreContracts.SmVerificationServerInfo
Type: Group
Host:
UserName:
Passphrase :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
ResourceGroupNames :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject :
Example 6: Creating a resource group and attaching hourly backup policy
Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description test -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Hourly_Full_log_Backup_Wtih_Ver_Policy_09959383";"StartTime"="05/21/2019 7:54 PM";"EndTime"="05/21/2019 8:03 PM";"ScheduleType"="Hourly";"RepeatTask_Every_Hour"="03:00"}
Example 7: Creating a resource group and attaching daily backup policy
Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with Daily SQL schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_SQL_Schedule_Policy_54615264 -schedulerinstance 'C226030161613-1\NAMEDINST1' -plugincode 'SCSQL' -schedulerrunasname 'DomainRunAs_54615264' -schedulertype 'SQL' -schedules @{"PolicyName"="Daily_Full_Log_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:09 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Daily";"daysInterval"="1"}
Example 8: Creating a resource group and attaching weekly backup policy
Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with hourly windows schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Weekly_Full_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:24 PM";"EndTime"="05/21/2019 8:41 PM";"ScheduleType"="Weekly";"DaysOfTheWeek"="Tuesday"}
Example 9: Creating a resource group and attaching monthly backup policy
Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with hourly windows schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Monthly_Full_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:51 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Monthly";"MonthsOfTheYear"="May,June";"daysOfTheMonth"="21,26,16"}
Example 10: Creating a new resource group in SCE plugin
Add-SmResourceGroup -ResourceGroupName RGName -Description test -Policies BackupPolicy -backupservers replicaServers -plugincode SCE -Resources @{"Host"="host.example.com";"Type"="SnapCenter Plug-in for Microsoft Exchange Server";"Names"="host.example.com4\newdb"}
Example 11: Creating a new resource group for Oracle Plug-in
Add-SmResourceGroup -ResourceGroupName 'mixedRG' -Resources @(@{"Host"="R809278EA03V1.HNK2.com";"Oracle Database"="DB11,DB12"},@{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1,appVol2"}) -plugincode 'SCO' -Policies 'testPolicy'
This example syntax creates a new resource group for Oracle Plug-in containing database and application volume resources.
Example 12: Creating a new resource group for Oracle Plug-in
Add-SmResourceGroup -ResourceGroupName 'appVolRG' -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1,appVol2"} -plugincode 'SCO' -Policies 'testPolicy'
This example syntax creates a new resource group for Oracle Plug-in with only application volume resources.
Example 6: Adding a resource group for UnixFileSystems plugin
Add-SmResourceGroup -ResourceGroupName 'RG_PS_linuxfs201_LVM1_12648' -Resources @{"Host"="linuxfs201.gdl.englab.netapp.com";"Type"="UnixFileSystems";Uid"="/netapp/VGNFS1/LVM1"} -plugincode 'UnixFileSystems' -Policies 'BackupPS_linuxfs201_LVM1_12648'
This example adds a resource group for UnixFileSystems plug-in.
Tag :
ByPassRunAs : False
CreationTime: 12/12/2023 8:29:30 AM
CustomText :
Description : Creating Resource Group
EmailBody :
EmailFrom :
EmailSMTPServer :
EmailSubject:
EmailTo :
EnableEmail :
EnableSysLog:
IsCustomSnapshot:
LastBackupStatus:
ModificationTime: 12/12/2023 8:29:30 AM
PluginProtectionGroupTypes : {UnixFileSystems}
Policies: {}
Type: Group
Host:
UserName:
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject :
