Cancel-SmJob
Cancels backup, clone, and verification jobs, which are in queued state. This cmdlet also cancels the running SnapCenter Plug-in for SQL Server and SnapCenter Plug-in for Oracle backup jobs.
Syntax
Cancel-SmJob [-JobId] <Int32> [-Force] <>
Detailed Description
Enables you to cancel the queued backup, clone, and verification jobs, as well as the running restore and clone jobs for all plug-ins. You can also cancel the running SnapCenter Plug-in for SQL Server and SnapCenter Plug-in for Oracle backup jobs.This cmdlet does not cancel running backup jobs for SnapCenter Plug-in for Exchange, SnapCenter Plug-in for VMware vSphere, SnapCenter Plug-in for SAP HANA, or SnapCenter Custom Plug-ins.This cmdlet replaces the Cancel-SmQueuedJob cmdlet that was available in earlier versions of SnapCenter.
| Name | Description | Required? | Pipeline Input | Default Value |
JobId |
Specifies the ID of the job you want to cancel. |
true |
false |
Force |
This optional parameter cancels a hung job that is running or queued. |
false |
false |
Example 1: Canceling a Running/Queued job
Cancel-SmJob -JobId 231
This example syntax cancels the backup job which is either running or queued.
Cancel-SmJob
Job 231 will be canceled. Do you want to continue?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Canceling a Running/Queued job with Force option
Cancel-SmJob -JobId 231 -Force
This example syntax cancels the backup job which is hung during canceling or running state.
Cancel-SmJob
