Connect-SdIscsiTarget
Establishes a session with your specified iSCSI target.
Syntax
Connect-SdIscsiTarget [-TargetNodeAddress] <String> [-TargetPortalAddress] <String> [-TargetPortalPortNumber] <UInt16> [-InitiatorPortalAddress] <String> [-CHAPUserName] <String> [-CHAPPassword] <String> [-Session] <String> [-Host] <String>
Detailed Description
Establishes a session with your specified iSCSItarget.
| Name | Description | Required? | Pipeline Input | Default Value |
TargetNodeAddress |
Specifies the target node address. |
true |
true (ByPropertyName) |
TargetPortalAddress |
Specifies the target portal address. |
true |
TargetPortalPortNumber |
Specifies the target portal port number. |
false |
InitiatorPortalAddress |
Specifies the initiator portal address. |
false |
CHAPUserName |
Specifies your CHAP user name. |
false |
CHAPPassword |
Specifies your CHAP password. |
false |
Session |
Specifies the session ID from Open-SmConnection. For internal use only. |
false |
Host |
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine. |
false |
Example 1: Connecting to an iSCSI target
PS C:\> Connect-SdIscsiTarget -TargetNodeAddress iqn.1992-08.com.netapp:sn.54053432d1f311e19455123478563412:vs.5 -TargetPortalAddress 172.17.175.84 -TargetPortalPortNumber 3260
This example syntax connects you to an iSCSI target.
