New-SmBackup
Initiates a new Snapshot copy job.
Syntax
New-SmBackup [-Resources] <Hashtable[]> [-DatasetName] <String> [-ResourceGroupName] <String> [-Policy] <String> [-Auth] <String> [-IsScheduled] <Boolean> [-ClusterName] <String> [-SMSBaseUrl] <String> [-IsNLBHost] <Boolean> [-ScheduleName] <String> [-ScheduleType] <SmSchedulerType> [-Guid1] <String> [-Guid2] <String> [-SnapShotLabel] <SmSPSnapShotLabel> [-HostName] <String> [-VerifyOnSecondary] <> [-EnableVerification] <>
Detailed Description
Initiates a new Snapshot copy job on the provided resource or the resources mapped to the provided resource group.
| Name | Description | Required? | Pipeline Input | Default Value |
Resources |
Specifies the resource which you want to backup. For Oracle Application Volume resource, format is -Resources @{"Host"="host1";"Application Volume"="appVol1"} |
false |
true (ByPropertyName) |
DatasetName |
Names the dataset you want to back up. |
false |
false |
ResourceGroupName |
false |
false |
Policy |
Specifies the policy you want to use for the backup operation. |
true |
false |
Auth |
This parameter is for internal use only. |
false |
false |
IsScheduled |
Internal switch to determine Cmdlet invocation by scheduler. |
false |
false |
ClusterName |
Internal switch for identifying the cluster host. |
false |
false |
SMSBaseUrl |
Internal switch that points to the SMS Base URL. |
false |
false |
IsNLBHost |
Internal switch that indicates whether this host is part of NLB. |
false |
false |
ScheduleName |
Internal switch that indicates schedule name. |
false |
false |
ScheduleType |
false |
false |
Guid1 |
false |
false |
Guid2 |
false |
false |
SnapShotLabel |
false |
false |
HostName |
Determines the host name (FQDN) for which the backup job has been scheduled. |
false |
false |
VerifyOnSecondary |
Specifies whether verification is enabled on secondary storage. |
false |
false |
EnableVerification |
Specifies whether verification of backups is enabled. Values are either $True or $False. |
false |
false |
Example 1: Backing up a resource group
New-SMBackup -ResourceGroupName FullOnlineDataset1 -Policy FullBackupPolicy
This example syntax backs up the specified resource group.
Example 2: Backing up resources
New-SMBackup -Policy FullBackupPolicy -Resources @{"Host"="scspr0101826001-sumanr.lab.netapp.com";"Oracle Database"="ong"}
This example syntax backs up the specified resources.
Example 3: Enabling verification of a backup
New-SMBackup -EnableVerification $true -VerifyOnSecondary $true -Policy FullBackupPolicy -Resources @{"Host"="scspr0101826001-sumanr.lab.netapp.com";"Oracle Database"="ong"}
This example syntax backs up the specified resources and verifies the backup when it completes.
Example 4: Triggering a new backup of the HANA resource
New-SMBackup -Resources @{"Host"="schana02.gdl.englab.netapp.com";"Uid"="MDC\R57";"PluginName"="hana"} -Policy "HANAPOLICY"
This example backs up the specified resources.
Name: Backup of Resource Group 'schana02_gdl_englab_netapp_com_hana_MDC_R57' with policy 'HANAPOLICY'
StartTime : 02-Oct-19 21:49:46
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 0
ApisJobKey :
ObjectId: 0
PluginCode : SCC
PluginName : PluginCreator
HostId : 0
RoleId :
JobIds : {}
Example 5: Backing up an Oracle Application Volume Resource
New-SMBackup -Policy ndvpolicy -Resources @{"Host"="R809278EA03V1.HNK2.com";"Application Volume"="appVol1"}
This example syntax backs up the specified Oracle Application Volume resource.
Example 6: Triggering a new backup of the UnixFileSystems resource
New-SMBackup -ResourceGroupName "RG_PS_linuxfs201_LVM1_12648" -Policy "BackupPS_linuxfs201_LVM1_12648"
Name: Backup of Resource Group 'RG_PS_linuxfs201_LVM1_12648' with policy
'BackupPS_linuxfs201_LVM1_12648'
StartTime : 12/12/2023 8:29:33 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 0
ApisJobKey :
ObjectId: 0
PluginCode : SCC
HostId : 0
RoleId :
JobIds : {}
ScsJobId:
