Remove-SmAlert
Removes the alert(s) from SnapCenter.
Syntax
Remove-SmAlert [-AlertIds] <String> [-EntityType] <SmEntityType> [-EntityName] <String> [-Severity] <SmAlertSeverity>
Detailed Description
Removes the alert(s) from SnapCenter. Either Alert Id(s) or Entity Type and Entity Name or Severity must be provided!
| Name | Description | Required? | Pipeline Input | Default Value |
AlertIds |
Specify the list of alert ids to be deleted. |
false |
true (ByPropertyName) |
EntityType |
Specify the entity type of the alert(s) needs to be deleted. ("Server", "Host", "Storage") |
false |
EntityName |
Specify the entity name of the alert(s) needs to be deleted. |
false |
Severity |
Specify the severity of the alert(s) needs to be deleted. "Informational", "Warning", "Critical") |
false |
Example 1: Remove one or more alerts by id(s)
Remove-SmAlert -AlertIds 100,101
This example syntax removes the specified alerts from SnapCenter.
Remove-SmAlert
Are you sure you want to remove the alert(s) ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Remove one or more alerts by id(s) without confirmation dialogue
Remove-SmAlert -AlertIds 100,101 -Confirm:$false
Example 1: Remove one or more alerts by EntityType and EntityName
Remove-SmAlert -EntityType Host -EntityName mtme.englab.netapp.com
This example syntax removes all the alerts of the given Host.
Remove-SmAlert
Example 1: Remove one or more alerts by Severity
Remove-SmAlert -Severity Warning
This example syntax removes all the warning alerts.
Remove-SmAlert
