Set-SmDomain
Modify a domain registered with SnapCenter Server.
Syntax
Set-SmDomain [-Name] <String> [-Protocol] <String> [-FQDN] <String> [-IPAddresses] <String> [-DCHostNames] <String> [-Credential] <PSCredential>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
NETBIOS name of the registered domain to be modified. |
true |
true (ByPropertyName) |
Protocol |
Protocol of the domain to be modified.By default the protocol value is LDAP. You can specify LDAPS to use the secured windows active directory communication. |
false |
FQDN |
FQDN of the domain to be modified.Used for both LDAP and LDAPS protocol, when you provide the correct FQDN while adding or modifying the domain with LDAP protocol, the domain resolves and the IP address that you might have entered using the IPAddresses parameter is not stored. |
false |
IPAddresses |
Domain IP Addresses of the disjoint domain to be modified.When you provide the correct FQDN while adding or modifying the domain, the domain resolves and the IP address is not stored. |
false |
DCHostNames |
Domain host name of the disjoint or the same domain to be modified.For LDAPS protocol, DCHostNames is a mandatory parameter. The IP address should resolve and the user should not be permitted to manually provide the IP address. |
false |
Credential |
Provides local workgorup administrator credentials to execute a Set-SmDomain cmdlet.This is an optional parameter only can exercise if Open-SmConnection is broken due to Active Directory connectivity using LDAPS protocol. |
false |
Example 1: Modify a domain registered with SnapCenter Server.
Set-SmDomain -Name ad12 -FQDN ad12.test.netapp.com -IPAddresses 192.168.0.44
Modified the domain ad12. Id : 0 Name : ad12 DomainFQDN : ad12.test.netapp.com DCHostIPAddresses : 192.168.0.44 TrustedDomains : CreatedOn : ModifiedOn : Port : 389 Protocol : LDAP DCHostNames:
Example 2: Modifying a registered domain protocol from LDAP to LDAPS.
Set-SmDomain -Name ad12 -DCHostNames WS2K12DC.ad12.test.netapp.com -Protocol LDAPS
Modified the domain ad12. Id : 0 Name : ad12 DomainFQDN : ad12.test.netapp.com DCHostIPAddresses : 192.168.0.44 TrustedDomains : CreatedOn : ModifiedOn : Port : 636 Protocol : LDAPS DCHostNames: WS2K12DC.ad12.test.netapp.com
Example 3: Modifying a registered domain protocol from LDAPS to LDAP.
Modified the domain ad12. Id : 0 Name : ad12 DomainFQDN : ad12.test.netapp.com DCHostIPAddresses : TrustedDomains : CreatedOn : ModifiedOn : Port : 389 Protocol : LDAP DCHostNames:
Example 4: Execute Set-SmDomain when Open-SmConnection is broken due to Active directory.
Set-SmDomain -Name ad12 -FQDN ad12.test.netapp.com -Credential administrator
