Licenses required by SnapCenter
SnapCenter requires several licenses to enable data protection of applications, databases, file systems, and virtual machines. The type of SnapCenter licenses you install depends on your storage environment and the features that you want to use.
| License | Where required | ||
SnapCenter Standard controller-based |
Required for FAS, AFF, ASA SnapCenter Standard license is a controller-based license and is included as part of NetApp ONTAP One. If you have the SnapManager Suite license, you also get the SnapCenter Standard license entitlement. If you want to install SnapCenter on a trial basis with FAS, AFF, or ASA storage, you can obtain a NetApp ONTAP One evaluation license by contacting the sales representative. For information on licenses included with NetApp ONTAP One, refer to Licenses included with NetApp ONTAP One.
SnapMirror or SnapVault |
ONTAP Either SnapMirror or SnapVault license is required if replication is enabled in SnapCenter. |
SnapRestore |
Required to restore and verify backups. On primary storage systems
FlexClone |
Required to clone databases and verification operations. On primary and secondary storage systems
Protocol licenses |
Required on SnapMirror destination systems to serve data if a source volume is unavailable. |
SnapCenter Standard licenses (optional) |
Secondary destinations
Single Mailbox Recovery (SMBR) licenses |
If you are using SnapCenter Plug-in for Exchange to manage Microsoft Exchange Server databases and Single Mailbox Recovery (SMBR), you would need additional license for SMBR which needs to be purchased separately based on user mailbox. NetApp® Single Mailbox Recovery has come to the end of availability (EOA) on May 12, 2023. For more information, refer CPC-00507. NetApp will continue to support customers that have purchased mailbox capacity, maintenance, and support through marketing part numbers introduced on June 24, 2020, for the duration of the support entitlement. NetApp Single Mailbox Recovery is a partner product provided by Ontrack. Ontrack PowerControls offers capabilities that are similar to those of NetApp Single Mailbox Recovery. Customers can procure new Ontrack PowerControls software licenses and Ontrack PowerControls maintenance and support renewals from Ontrack (through licensingteam@ontrack.com) for granular mailbox recovery after the May 12, 2023, EOA date. |
SnapCenter Advanced and SnapCenter NAS File Services licenses are deprecated, and are no longer available. The standard license and capacity-based license are no longer required for Amazon FSx for NetApp ONTAP, ONTAP Select, Cloud Volumes ONTAP, and Azure NetApp Files. |
You should install one or more SnapCenter licenses. For information on how to add licenses, see Add SnapCenter Standard controller-based licenses.
