What's new in SnapCenter Software 6.0
The 6.0 release of SnapCenter Software includes several new features and enhancements.
Update | Description |
Support for enterprise workloads plug-ins with NetApp support |
SnapCenter provides plug-ins to manage workloads such as PostgreSQL, MySQL, and IBM Db2. You can auto discover, back up, restore, mount, and clone the workloads. SnapCenter also provides plug-ins to manage workloads such as SAP ASE, SAP MaxDB, MongoDB, Oracle Applications, and ONTAP storage. You can back up, restore, and clone the workloads. |
Support for Linux version of SnapCenter for both cloud and on-premises workloads |
Separate SnapCenter binaries are now available for Linux flavors such as Red Hat Enterprise Linux (RHEL), Oracle Linux, and SUSE Linux Enterprise Server (SLES).
You can now use SnapCenter to configure SnapMirror active sync features and effectively back up, restore, and clone SAN workloads for databases and VMware VMs. This ensures transparent application failover and business continuity. |
You can now use SnapCenter to protect Microsoft SQL Server databases deployed on SMB3 protocol in ONTAP, Azure NetApp Files, Amazon FSx for NetApp ONTAP, and Cloud Volumes ONTAP. |
SnapCenter now supports NVMe over TCP protocol to back up and recover applications and file systems. |
Support for VMware vSphere Virtual Volumes (vVols) |
You can now use SnapCenter to protect your databases and file systems deployed on vVols. |
