The smo profile create command
You can run the profile create command to create a profile of a database in a repository. You must mount the database before you run this command.
Syntax
smo profile create
-profile profile
\[-profile-password profile_password\]
-repository
-dbname repo_service_name
-host repo_host
-port repo_port
-login -username repo_username
-database
-dbname db_dbname
-host db_host
[-sid db_sid\]
[-login
\[-username db_username -password db_password -port db_port\]
\[-asminstance -asmusername asminstance_username -asmpassword asminstance_password\]]
[-rman \{-controlfile \| \{-login
-username rman_username -password rman_password\}
-tnsname rman_tnsname\}\}]
\[-osaccount osaccount \]
\[-osgroup osgroup\]
[-retain
\[-hourly \[-count n\] \[-duration m\]\]
\[-daily \[-count n\] \[-duration m\]]
\[-weekly \[-count n\] \[-duration m\]]
\[-monthly \[-count n\] \[-duration m\]]]]
-comment comment
-snapname-pattern pattern
[-protect \[-protection-policy policy\]]
[-summary-notification]
[-notification
\[-success
-email email_address1,email_address2
-subject subject_pattern\]
\[-failure
-subject subject_pattern]
[-separate-archivelog-backups
-retain-archivelog-backups
-hours hours |
-days days |
-weeks weeks |
-months months
[-protect \[-protection-policy policy_name \| -noprotect]
[-include-with-online-backups \| -no-include-with-online-backups]]
[-dump]
[-quiet | -verbose]
-profile profile
Specifies the name of the profile. This name can be up to 30 characters long and must be unique within the host.
Specify the password for the profile.
-repository
The options that follow -repository specify the details of the database that stores the profile.
Specifies the name of the database that stores the profile. Use either the global name or the SID.
-host repo_host
Specifies the name or IP address of the host computer the repository database runs on.
-sid db_sid
Specifies the system identifier of the database that the profile describes. By default, SnapManager uses the database name as the system identifier. If the system identifier is different from the database name, you must specify it with the -sid option.
For example, if you are using Oracle Real Application Clusters (RAC), you must specify the system identifier of the RAC instance on the RAC node from which SnapManager is executed.
-login
Specifies the repository login details.
Specifies the user name needed to access the repository database.
-port repo_port
Specifies the TCP port number used to access the repository database.
-database
Specifies the details of the database that the profile describes. This is the database that will be backed up, restored, or cloned.
-dbname db_dbname
Specifies the name of the database that the profile describes. You can use either the global name or the system identifier.
-host db_host db_host
Specifies the name or IP address of the host computer on which the database runs.
-asminstance
Specifies the credentials that are used to log in to the Automatic Storage Management (ASM) instance.
Specifies the user name used to log in to the ASM instance.
Specifies the password used to log in to ASM instance.
-login
Specifies the database login details.
Specifies the user name needed to access the database that the profile describes.
Specifies the password needed to access the database that the profile describes.
-port db_port
Specifies the TCP port number used to access the database that the profile describes.
-rman
Specifies the details that SnapManager uses to catalog backups with Oracle Recovery Manager (RMAN).
-controlfile
Specifies the target database control files instead of a catalog as the RMAN repository.
-login
Specifies the RMAN login details.
Specifies the password used to log in to the RMAN catalog.
Specifies the user name used to log in to the RMAN catalog.
-tnsname tnsname
Specifies the tnsname connection name (this is defined in the tsname.ora file).
Specifies the name of the Oracle database user account. SnapManager uses this account to perform the Oracle operations such as startup and shutdown. It is typically the user who owns the Oracle software on the host, for example, oracle.
-osgroup osgroup
Specifies the name of the Oracle database group name associated with the oracle account.
-retain [-hourly [-count n] [-duration m]] [-daily [-count n] [-duration m]] [-weekly [-count n] [-duration m]] [-monthly [-count n] [-duration m]]
Specifies the retention policy for a backup where either or both of a retention count along with a retention duration for a retention class (hourly, daily, weekly, monthly).
For each retention class, either or both of a retention count or a retention duration may be specified. The duration is in units of the class (for example, hours for hourly, days for daily). For instance, if the user specifies only a retention duration of 7 for daily backups, then SnapManager will not limit the number of daily backups for the profile (because the retention count is 0), but SnapManager will automatically delete daily backups created over 7 days ago.
-comment comment
Specifies the comment for a profile describing the profile domain.
Specifies the naming pattern for Snapshot copies. You can also include custom text, for example, HAOPS for highly available operations, in all Snapshot copy names. You can change the Snapshot copy naming pattern when you create a profile or after the profile has been created. The updated pattern applies only to Snapshot copies that have not yet been created. Snapshot copies that exist retain the previous Snapname pattern. You can use several variables in the pattern text.
-protect -protection-policy policy
Indicates whether the backup should be protected to secondary storage.
If -protectis specified without -protection-policy, then the dataset will not have a protection policy. If -protect is specified and -protection-policy is not set when the profile is created, then it may be set later bysmo profile update command or set by the storage administrator through Protection Manager's console. -
Specifies that summary email notification is enabled for the new profile.
-notification -success-email e-mail_address1,e-mail address2 -subject subject_pattern
Specifies that email notification is enabled for the new profile so that emails are received by recipients when the SnapManager operation succeeds. You must enter a single email address or multiple email addresses to which email alerts will be sent and an email subject pattern for the new profile.
You can also include custom subject text for the new profile. You can change the subject text when you create a profile or after the profile has been created. The updated subject applies only to the emails that are not sent. You can use several variables for the email subject.
-notification -failure -email e-mail_address1,e-mail address2 -subject subject_pattern
Specifies that enable email notification is enabled for the new profile so that emails are received by recipients when the SnapManager operation fails. You must enter a single email address or multiple email addresses to which email alerts will be sent and an email subject pattern for the new profile.
Specifies that the archive log backup is separated from datafile backup. This is an optional parameter you can provide while creating the profile. After you separate the backup using this option, you can either take data files-only backup or archive logs-only backup.
-retain-archivelog-backups -hours hours | -daysdays | -weeksweeks| -monthsmonths
Specifies that the archive log backups are retained based on the archive log retention duration (hourly, daily, weekly, monthly).
protect [-protection-policypolicy_name] | -noprotect
Specifies to protect the archive log files based on the archive log protection policy.
The -noprotect option specifies not to protect the archive log files.
-quiet
Displays only error messages in the console. The default is to display error and warning messages.
-verbose
Displays error, warning, and informational messages in the console.
Specifies that the archive log backup is included along with the online database backup.
Specifies that the archive log backups are not included along with the online database backup.
-dump
Specifies that the dump files are collected after the successful profile create operation.
Example
The following example shows the creation of a profile with hourly retention policy and email notification:
smo profile create -profile test_rbac -profile-password netapp -repository -dbname SMOREP -host hostname.org.com -port 1521 -login -username smorep -database -dbname RACB -host saal -sid racb1 -login -username sys -password netapp -port 1521 -rman -controlfile -retain -hourly -count 30 -verbose Operation Id [8abc01ec0e78ebda010e78ebe6a40005] succeeded.
Related information
