Reporting options for a selected cluster
Learn about the Reporting drop-down menu in the side panel:
Capacity
On the Capacity page of the Reporting drop-down menu for a selected cluster, you can view details about the overall cluster space that is provisioned into volumes. Capacity information bars provide the current state and forecasts of block and metadata storage capacity for the cluster. The corresponding graphs provide additional methods for analyzing the cluster data.
For details about severity levels and cluster fullness, see the Element Software documentation. |
The following descriptions give details about the block capacity, metadata capacity, and provisioned space on the selected cluster.
| Block capacity | ||
Heading |
Description |
Forecast |
Used Capacity |
Current used capacity of the cluster block. |
Not applicable |
Warning Threshold |
The current warning threshold. |
Forecast for when the warning threshold will be reached. |
Error Threshold |
The current error threshold. |
Forecast for when the error threshold will be reached. |
Total Capacity |
The total capacity for the block. |
Forecast for when the critical threshold will be reached. |
Current State |
Current state of the block. |
For details about severity levels, see the Element Software documentation. |
Metadata capacity |
Heading |
Description |
Used Capacity |
The metadata cluster capacity used for this cluster. |
Total Capacity |
The total available metadata capacity for this cluster and the critical threshold forecast. |
Current State |
The current state of the metadata capacity for this cluster. |
Provisioned space |
Heading |
Description |
Provisioned Space |
The amount of space that is currently provisioned on the cluster. |
Max Provisioned Space |
The maximum space that can be provisioned on the cluster. |
Efficiency
On the Efficiency page of the cluster Reporting drop-down menu for a selected cluster, you can view details about thin provisioning, deduplication, and compression on the cluster when you move your mouse pointer over data points on the graph.
All combined efficiencies are calculated by simple multiplication of the reported factor values. |
The following descriptions give details about calculated efficiencies on the selected cluster.
| Heading | Description |
Overall efficiency |
The global efficiency of thin provisioning, deduplication, and compression multiplied together. These calculations do not take into account the double helix feature built into the system. |
Deduplication and Compression |
The combined effect of space saved by using deduplication and compression. |
Thin Provisioning |
The amount of space saved by using this feature. This number reflects the delta between the capacity allocated for the cluster and the amount of data actually stored. |
Deduplication |
The ratio multiplier of the amount of space that was saved by not storing duplicate data in the cluster. |
Compression |
The effect of data compression on stored data in the cluster. Different data types compress at different rates. For example, text data and most documents easily compress to a smaller space, but video and graphical images typically do not. |
Performance
On the Performance page of the Reporting drop-down menu for a selected cluster, you can view details about IOPS usage, throughput, and cluster utilization by selecting the category and filtering based on time period.
Node Utilization
On the Node Utilization page of the Reporting drop-down menu for a selected cluster, you can select and view each node.
Beginning with Element 12.8, node utilization information is available as nodeHeat using the GetNodeStats and ListNodeStats API methods. The nodeHeat object is a member of the nodeStats object and displays node utilization information based on the ratio of primary total IOPS or total IOPS to the configured IOPS averaged over time. The node utilization graph shows this as a percentage derived from the metric recentPrimaryTotalHeat.
Error Log
On the Error Log page of the Reporting drop-down menu for a selected cluster, you can view information about unresolved or resolved errors that have been reported by the cluster. This information can be filtered and exported to a comma-separated values (CSV) file. For details about severity levels, see the Element Software documentation.
The following information is reported for the selected cluster.
ID |
ID for a cluster fault. |
Date |
The date and time the fault was logged. |
Severity |
This can be warning, error, critical, or best practice. |
Type |
This can be node, drive, cluster, service, or volume. |
Node ID |
Node ID for the node that this fault refers to. Included for node and drive faults; otherwise set to - (dash). |
Node Name |
The system-generated node name. |
Drive ID |
Drive ID for the drive that this fault refers to. Included for drive faults; otherwise set to - (dash). |
Resolved |
Displays if the cause of the error has been resolved. |
Resolution Time |
Displays the time an issue was resolved. |
Error Code |
A descriptive code that indicates what caused the fault. |
Details |
Description of the fault with additional details. |
Events
On the Events page of the Reporting drop-down menu for a selected cluster, you can select between the Events and gcEvents tabs to view information about key events that have occurred on the cluster. By default, selecting Events shows all of the events except for gcEvents to improve readability. In order to see all events, including gcEvents, select the tab labeled gcEvents. This information can be filtered and exported to a CSV file.
Event ID |
Unique ID associated with each event. |
Event Time |
The time the event occurred. |
Type |
The type of event being logged, for example, API events, clone events, or gc events. See the Element Software documentation for more information. |
Message |
Message associated with the event. |
Service ID |
The service that reported the event (if applicable). |
Node ID |
The node that reported the event (if applicable). |
Drive ID |
The drive that reported the event (if applicable). |
Details |
Information that helps identify why the event occurred. |
Alerts
On the Alerts page of the Reporting drop-down menu for a selected cluster, you can view unresolved or resolved cluster alerts. This information can be filtered and exported to a CSV file. For details about severity levels, see the Element Software documentation.
Triggered |
The time the alert was triggered in SolidFire Active IQ, not on the cluster itself. |
Last Notified |
The time the most recent alert email was sent. |
Resolved |
Shows if the cause of the alert has been resolved. |
Policy |
This is the user-defined alert policy name. |
Severity |
Severity assigned at the time the alert policy was created. |
Destination |
The email address or addresses selected to receive the alert email. |
Trigger |
The user-defined setting that triggered the alert. |
iSCSI Sessions
On the iSCSI Sessions page of the Reporting drop-down menu for a selected cluster, you can view details about the number of active sessions on the cluster and the number of iSCSI sessions that have occurred on the cluster.
Expand the iSCSI Sessions example
You can move your mouse pointer over a data point on the graph to find the number of sessions for a defined time period:
Active Sessions: The number of iSCSI sessions that are attached and active on the cluster.
Peak Active Sessions: The maximum number of iSCSI sessions that have occurred on the cluster in the last 24 hours.
This data includes iSCSI sessions generated by FC nodes. |
Virtual Networks
On the Virtual Networks page of the Reporting drop-down menu for a selected cluster, you can view the following information about virtual networks configured on the cluster.
ID |
Unique ID of the VLAN network. This is assigned by the system. |
Name |
Unique user-assigned name for the VLAN network. |
VLAN ID |
VLAN tag assigned when the virtual network was created. |
SVIP |
Storage virtual IP address assigned to the virtual network. |
Netmask |
Netmask for this virtual network. |
Gateway |
Unique IP address of a virtual network gateway. VRF must be enabled. |
VRF Enabled |
Shows if virtual routing and forwarding is enabled or not. |
IPs Used |
The range of virtual network IP addresses used for the virtual network. |
API Collection
On the API Collection page of the Reporting drop-down menu for a selected cluster, you can view the API methods used by the NetApp SolidFire Active IQ. For detailed descriptions of these methods, see the Element Software API documentation.
In addition to these methods, SolidFire Active IQ makes some internal API calls used by NetApp Support and engineering to monitor cluster health. These calls are not documented as they can be disruptive to cluster functionality if used incorrectly. If you require a complete list of SolidFire Active IQ API collections, you must contact NetApp Support. |
