Register Cloud Volumes ONTAP pay-as-you-go systems
Support from NetApp is included with Cloud Volumes ONTAP pay-as-you-go (PAYGO) systems, but you must first activate support by registering the systems with NetApp.
Registering a PAYGO system with NetApp is required to upgrade ONTAP software using any of the methods described on this page.
A system that isn't registered for support will still receive the software update notifications that appear in the NetApp Console when a new version is available. But you will need to register the system before you can upgrade the software. |
Steps
If you have not yet added your NetApp Support Site account to the Console, go to Account Settings and add it now.
On the Systems page, double-click the name of the system you want to register..
On the Overview tab, select the Features panel and then select the pencil icon next to Support Registration.
Select a NetApp Support Site account and select Register.
Result
The system is registered with NetApp.
