Create and assign storage grades
Storage grades identify the type of storage used by a Storage Node. You can create storage grades if you want ILM rules to place certain objects on certain Storage Nodes.
Before you begin
About this task
When you first install StorageGRID, the Default storage grade is automatically assigned to every Storage Node in your system. As required, you can optionally define custom storage grades and assign them to different Storage Nodes.
Using custom storage grades allows you to create ILM storage pools that contain only a specific type of Storage Node. For example, you might want certain objects to be stored on your fastest Storage Nodes, such as StorageGRID all-flash storage appliances.
Note Storage Nodes can be configured during installation to contain only object metadata and not object data. Metadata-only Storage Nodes can't be assigned a storage grade. For more information, see Types of Storage Nodes.
If storage grade is not a concern (for example, all Storage Nodes are identical), you can skip this procedure and use the includes all storage grades selection for the storage grade when you create storage pools. Using this selection ensures that the storage pool will include every Storage Node at the site, regardless of its storage grade.
Note Don't create more storage grades than necessary. For example, don't create a storage grade for each Storage Node. Instead, assign each storage grade to two or more nodes. Storage grades assigned to only one node can cause ILM backlogs if that node becomes unavailable.
Steps
  1. Select ILM > Storage grades.
  2. Define custom storage grades:
    1. For each custom storage grade you want to add, select Insert insert icon to add a row.
    2. Enter a descriptive label.
      Storage Grades page
    3. Select Apply Changes.
    4. Optionally, if you need to modify a saved label, select Edit edit icon and select Apply Changes.
      Note You can't delete storage grades.
  3. Assign new storage grades to Storage Nodes:
    1. Locate the Storage Node in the LDR list, and select its Edit icon edit icon.
    2. Select the appropriate storage grade from the list.
      Storage Grades page
      Note Assign a storage grade to a given Storage Node only once. A Storage Node recovered from failure maintains the previously assigned storage grade. Don't change this assignment after the ILM policy is activated. If the assignment is changed, data is stored based on the new storage grade.
