Step 6: Monitor Decommission
From Step 6 (Monitor Decommission) of the Decommission Site page wizard, you can monitor the progress as the site is removed.
About this task
When StorageGRID removes a connected site, it removes nodes in this order:
  1. Gateway Nodes
  2. Admin Nodes
  3. Storage Nodes
When StorageGRID removes a disconnected site, it removes nodes in this order:
  1. Gateway Nodes
  2. Storage Nodes
  3. Admin Nodes
Each Gateway Node or Admin Node might only require a few minutes or an hour to remove; however, Storage Nodes might take days or weeks.
Steps
  1. As soon as a new Recovery Package has been generated, download the file.
    Site Decommission Step 6 Recovery Package
    Note Download the Recovery Package as soon as possible to ensure you can recover your grid if something goes wrong during the decommission procedure.
    1. Select the link in the message, or select MAINTENANCE > System > Recovery package.
    2. Download the .zip file.
      See the instructions for downloading the Recovery Package.
    Note The Recovery Package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system.
  2. Using the Data Movement chart, monitor the movement of object data from this site to other sites.
    Data movement started when you activated the new ILM policy in Step 3 (Revise ILM Policy). Data movement will occur throughout the decommission procedure.
    Decommission Site Step 6 Data Movement
  3. In the Node Progress section of the page, monitor the progress of the decommission procedure as nodes are removed.
    When a Storage Node is removed, each node goes through a series of stages. Although most of these stages occur quickly or even imperceptibly, you might need to wait days or even weeks for other stages to complete, based on how much data needs to moved. Additional time is required to manage erasure-coded data and re-evaluate ILM.
    Decommission Site Step 6 Storage Node
    If you are monitoring the progress of a connected site decommission, refer to this table to understand the decommission stages for a Storage Node:
    Stage Estimated duration
    Pending
    Minute or less
    Wait for Locks
    Minutes
    Prepare Task
    Minute or less
    Marking LDR Decommissioned
    Minutes
    Decommissioning Replicated and Erasure-Coded Data
    Hours, days, or weeks based on the amount of data
    Note: If you need to perform other maintenance activities, you can pause the site decommission during this stage.
    LDR Set State
    Minutes
    Flush Audit Queues
    Minutes to hours, based on the number of messages and network latency.
    Complete
    Minutes
    If you are monitoring the progress of a disconnected site decommission, refer to this table to understand the decommission stages for a Storage Node:
    Pending
    Minute or less
    Wait for Locks
    Minutes
    Prepare Task
    Minute or less
    Disable External Services
    Minutes
    Certificate Revocation
    Minutes
    Node Unregister
    Minutes
    Storage Grade Unregister
    Minutes
    Storage Group Removal
    Minutes
    Entity Removal
    Minutes
    Complete
    Minutes
  4. After all nodes have reached the Complete stage, wait for the remaining site decommission operations to complete.
    • During the Repair Cassandra step, StorageGRID makes any necessary repairs to the Cassandra clusters that remain in your grid. These repairs might take several days or more, depending on how many Storage Nodes remain in your grid.
      Decommission Site Step 6 Repair Cassandra
    • During the Deactivate EC Profiles & Delete Storage Pools step, the following ILM changes are made:
      • Any erasure-coding profiles that referred to the site are deactivated.
      • Any Storage Pools that referred to the site are deleted.
        Note The All Storage Nodes storage pool (StorageGRID 11.6 and earlier) is also removed because it uses the All Sites site.
    • Finally, during the Remove Configuration step, any remaining references to the site and its nodes are removed from the rest of the grid.
      Decommission Site Step 6 Remove Configuration
  5. When the decommission procedure has completed, the Decommission Site page shows a success message, and the removed site is no longer shown.
    Decommission Site Success Message
After you finish
Complete these tasks after you complete the site decommission procedure:
  • Ensure that the drives of all Storage Nodes in the decommissioned site are wiped clean. Use a commercially available data wiping tool or service to permanently and securely remove data from the drives.
  • If the site included one or more Admin Nodes and single sign-on (SSO) is enabled for your StorageGRID system, remove all relying party trusts for the site from Active Directory Federation Services (AD FS).
  • After the nodes have been gracefully powered off automatically as part of the connected site decommission procedure, remove the associated virtual machines.
