Disable alert rules
You can change the enabled/disabled state for a default or custom alert rule.
Before you begin
About this task
When an alert rule is disabled, its expressions aren't evaluated and no alerts are triggered.
Caution In general, disabling a default alert rule is not recommended. If an alert rule is disabled, you might not detect an underlying problem until it prevents a critical operation from completing.
Steps
  1. Select ALERTS > Rules.
    The Alert Rules page appears.
  2. Select the radio button for the alert rule you want to disable or enable.
  3. Select Edit rule.
    The Edit Rule dialog box appears.
  4. Select or clear the Enabled checkbox to determine if this alert rule is currently enabled.
    If an alert rule is disabled, its expressions aren't evaluated and no alerts are triggered.
    Note If you disable the alert rule for a current alert, you must wait a few minutes for the alert to no longer display as an active alert.
  5. Select Save.
    Disabled appears in the Status column.
