SDEL audit message for S3 DELETE transactions in StorageGRID
When an S3 client issues a DELETE transaction, a request is made to remove the specified object or bucket, or to remove a bucket/object subresource. This message is issued by the server if the transaction is successful.
Code Field Description
CBID
Content Block Identifier
The unique identifier of the content block requested. If the CBID is unknown, this field is set to 0. Operations on buckets don't include this field.
CNCH
Consistency Control Header
The value of the Consistency-Control HTTP request header, if present in the request.
CNID
Connection Identifier
The unique system identifier for the TCP/IP connection.
CSIZ
Content Size
The size of the deleted object in bytes. Operations on buckets don't include this field.
DMRK
Delete Marker Version ID
The version ID of the delete marker created when deleting an object from a versioned bucket. Operations on buckets don't include this field.
GFID
Grid Federation Connection ID
The connection ID of the grid federation connection associated with a cross-grid replication delete request. Only included in audit logs on the destination grid.
GFSA
Grid Federation Source Account ID
The account ID of the tenant on the source grid for a cross-grid replication delete request. Only included in audit logs on the destination grid.
HTRH
HTTP Request Header
List of logged HTTP request header names and values as selected during configuration.
X-Forwarded-For is automatically included if it is present in the request and if the X-Forwarded-For value is different from the request sender IP address (SAIP audit field).
x-amz-bypass-governance-retention is automatically included if it is present in the request.
MTME
Last Modified Time
The Unix timestamp, in microseconds, indicating when the object was last modified.
RSLT
Result Code
Result of the DELETE transaction. Result is always:
SUCS: Successful
S3AI
S3 tenant account ID (request sender)
The tenant account ID of the user who sent the request. An empty value indicates anonymous access.
S3AK
S3 Access Key ID (request sender)
The hashed S3 access key ID for the user that sent the request. An empty value indicates anonymous access.
S3BK
S3 Bucket
The S3 bucket name.
S3KY
S3 Key
The S3 key name, not including the bucket name. Operations on buckets don't include this field.
S3SR
S3 Subresource
The bucket or object subresource being operated on, if applicable.
SACC
S3 tenant account name (request sender)
The name of the tenant account for the user who sent the request. Empty for anonymous requests.
SAIP
IP address (request sender)
The IP address of the client application that made the request.
SBAC
S3 tenant account name (bucket owner)
The tenant account name for the bucket owner. Used to identify cross-account or anonymous access.
SBAI
S3 tenant account ID (bucket owner)
The tenant account ID of the owner of the target bucket. Used to identify cross-account or anonymous access.
SGRP
Site (Group)
If present, the object was deleted at the site specified, which is not the site where the object was ingested.
SUSR
S3 User URN (request sender)
The tenant account ID and the user name of the user making the request. The user can either be a local user or an LDAP user. For example: urn:sgws:identity::03393893651506583485:root
TIME
Time
Total processing time for the request in microseconds.
TLIP
Trusted Load Balancer IP Address
If the request was routed by a trusted Layer 7 load balancer, the IP address of the load balancer.
UUDM
Universally Unique Identifier for a Delete Marker
The identifier of a delete marker. Audit log messages specify either UUDM or UUID, where UUDM indicates a delete marker created as a result of an object delete request, and UUID indicates an object.
UUID
The identifier of the object within the StorageGRID system.
VSID
Version ID
The version ID of the specific version of an object that was deleted. Operations on buckets and objects in unversioned buckets don't include this field.
