Guidelines for adding metadata capacity in StorageGRID
To ensure that adequate space is available for object metadata, you might need to perform an expansion procedure to add new Storage Nodes at each site.
StorageGRID reserves space for object metadata on volume 0 of each Storage Node. Three copies of all object metadata are maintained at each site, evenly distributed across all Storage Nodes.
You can use the Grid Manager to monitor the metadata capacity of Storage Nodes and to estimate how quickly metadata capacity is being consumed. In addition, the Low metadata storage alert is triggered for a Storage Node when the used metadata space reaches certain thresholds.
Note that a grid's object metadata capacity might be consumed faster than its object storage capacity, depending on how you use the grid. For example, if you typically ingest large numbers of small objects or add large quantities of user metadata or tags to objects, you might need to add Storage Nodes to increase metadata capacity even though sufficient object storage capacity remains.
For more information, see the following:
Guidelines for increasing metadata capacity
Before adding Storage Nodes to increase metadata capacity, review the following guidelines and limitations:
  • Assuming sufficient object storage capacity is available, having more space available for object metadata increases the number of objects you can store in your StorageGRID system.
  • You can increase a grid's metadata capacity by adding one or more Storage Nodes to each site.
  • The actual space reserved for object metadata on any given Storage Node depends on the Metadata Reserved Space storage option (system-wide setting), the amount of RAM allocated to the node, and the size of the node's volume 0.
  • You can't increase metadata capacity by adding storage volumes to existing Storage Nodes, because metadata is stored only on volume 0.
  • You can't increase metadata capacity by adding a new site.
  • StorageGRID keeps three copies of all object metadata at every site. For this reason, the metadata capacity for your system is limited by the metadata capacity of your smallest site.
  • When adding metadata capacity, you should add the same number of Storage Nodes to each site.
Metadata-only Storage Nodes have specific hardware requirements:
  • When using StorageGRID appliances, metadata-only nodes can be configured only on SGF6112 appliances with twelve 1.9 TB or twelve 3.8 TB drives.
  • When using software-based nodes, metadata-only node resources must match the existing Storage Nodes resources. For example:
    • If the existing StorageGRID site is using SG6000 or SG6100 appliances, the software-based metadata-only nodes must meet the following minimum requirements:
      • 128 GB RAM
      • 8 core CPU
      • 8 TB SSD or equivalent storage for the Cassandra database (rangedb/0)
    • If the existing StorageGRID site is using virtual Storage Nodes with 24 GB RAM, 8 core CPU, and 3 TB or 4TB of metadata storage, the software-based metadata-only nodes should use similar resources (24 GB RAM, 8 core CPU, and 4TB of metadata storage (rangedb/0)).
  • When adding a new StorageGRID site, the new site total metadata capacity should, at minimum, match existing StorageGRID sites and new site resources should match the Storage Nodes at existing StorageGRID sites.
How metadata is redistributed when you add Storage Nodes
When you add Storage Nodes in an expansion, StorageGRID redistributes the existing object metadata to the new nodes at each site, which increases the overall metadata capacity of the grid. No user action is required.
The following figure shows how StorageGRID redistributes object metadata when you add Storage Nodes in an expansion. The left side of the figure represents volume 0 of three Storage Nodes before an expansion. Metadata is consuming a relatively large portion of each node's available metadata space, and the Low metadata storage alert has been triggered.
The right side of the figure shows how the existing metadata is redistributed after two Storage Nodes are added to the site. The amount of metadata on each node has decreased, the Low metadata storage alert is no longer triggered, and the space available for metadata has increased.
Diagram of metadata redistributed after two Storage Nodes added
