Edit a storage pool in StorageGRID
You can edit a storage pool to change its name or to update sites and storage grades.
Before you begin
About this task
If you are adding a new site or storage grade to a storage pool that is used in the active ILM policy, be aware that the Storage Nodes in the new site or storage grade will not be used automatically. To force StorageGRID to use a new site or storage grade, you must activate a new ILM policy after saving the edited storage pool.
Steps
  1. Select ILM > Storage pools.
  2. Select the checkbox for the storage pool you want to edit.
    You can't edit the All Storage Nodes storage pool (StorageGRID 11.6 and earlier).
  3. Select Edit.
  4. As required, change the storage pool name.
  5. As required, select other sites and storage grades.
    You are prevented from changing the site or storage grade if the storage pool is used in an erasure-coding profile and the change would cause the erasure-coding scheme to become invalid. For example, if a storage pool used in a erasure-coding profile currently includes a storage grade with only one site, you are prevented from using a storage grade with two sites because the change would make the erasure-coding scheme invalid.
    Caution Adding or removing sites from an existing storage pool won’t move any existing erasure-encoded data. If you want to move the existing data from the site, you must create a new storage pool and EC profile to re-encode the data.
  6. Select Save.
After you finish
If you added a new site or storage grade to a storage pool used in the active ILM policy, activate a new ILM policy to force StorageGRID to use the new site or storage grade. For example, clone your existing ILM policy and then activate the clone. See Work with ILM rules and ILM policies.
