Create groups for an S3 tenant in StorageGRID
You can manage permissions for S3 user groups by importing federated groups or creating local groups.
Before you begin
Access the Create group wizard
As your first step, access the Create group wizard.
Steps
  1. Select Access Management > Groups.
  2. If your tenant account has the Use grid federation connection permission, confirm that a blue banner appears, indicating that new groups created on this grid will be cloned to the same tenant on the other grid in the connection. If this banner does not appear, you might be signed in to the tenant's destination grid.
    image of blue banner on Groups page of tenant source grid
  3. Select Create group.
Choose a group type
You can create a local group or import a federated group.
Steps
  1. Select the Local group tab to create a local group, or select the Federated group tab to import a group from the previously configured identity source.
    If single sign-on (SSO) is enabled for your StorageGRID system, users belonging to local groups will not be able to sign in to the Tenant Manager, although they can use client applications to manage the tenant's resources, based on group permissions.
  2. Enter the group's name.
    • Local group: Enter both a display name and a unique name. You can edit the display name later.
      Note If your tenant account has the Use grid federation connection permission, a cloning error will occur if the same Unique name already exists for the tenant on the destination grid.
    • Federated group: Enter the unique name. For Active Directory, the unique name is the name associated with the sAMAccountName attribute. For OpenLDAP, the unique name is the name associated with the uid attribute.
  3. Select Continue.
Manage group permissions
Group permissions control which tasks users can perform in the Tenant Manager and Tenant Management API.
Steps
  1. For Access mode, select one of the following:
    • Read-write (default): Users can sign in to Tenant Manager and manage the tenant configuration.
    • Read-only: Users can only view settings and features. They can't make any changes or perform any operations in the Tenant Manager or Tenant Management API. Local read-only users can change their own passwords.
      Note If a user belongs to multiple groups and any group is set to Read-only, the user will have read-only access to all selected settings and features.
  2. Select one or more permissions for this group.
  3. Select Continue.
Set S3 group policy
The group policy determines which S3 access permissions users will have.
Steps
  1. Select the policy you want to use for this group.
    Group policy Description
    No S3 Access
    Default. Users in this group don't have access to S3 resources, unless access is granted with a bucket policy. If you select this option, only the root user will have access to S3 resources by default.
    Read Only Access
    Users in this group have read-only access to S3 resources. For example, users in this group can list objects and read object data, metadata, and tags. When you select this option, the JSON string for a read-only group policy appears in the text box. You can't edit this string.
    Full Access
    Users in this group have full access to S3 resources, including buckets. When you select this option, the JSON string for a full-access group policy appears in the text box. You can't edit this string.
    Ransomware Mitigation
    This example policy applies to all buckets for this tenant. Users in this group can perform common actions, but can't permanently delete objects from buckets that have object versioning enabled.
    Tenant Manager users who have the Manage all buckets permission can override this group policy. Limit the Manage all buckets permission to trusted users, and use Multi-Factor Authentication (MFA) where available.
    Custom
    Users in the group are granted the permissions you specify in the text box.
  2. If you selected Custom, enter the group policy. Each group policy has a size limit of 5,120 bytes. You must enter a valid JSON formatted string.
    For detailed information about group policies, including language syntax and examples, see Example group policies.
  3. If you are creating a local group, select Continue. If you are creating a federated group, select Create group and Finish.
Add users (local groups only)
You can save the group without adding users, or you can optionally add any local users that already exist.
Note If your tenant account has the Use grid federation connection permission, any users you select when you create a local group on the source grid aren't included when the group is cloned to the destination grid. For this reason, don't select users when you create the group. Instead, select the group when you create the users.
Steps
  1. Optionally, select one or more local users for this group.
  2. Select Create group and Finish.
    The group you created appears in the list of groups.
    If your tenant account has the Use grid federation connection permission and you are on the tenant's source grid, the new group is cloned to the tenant's destination grid. Success appears as the Cloning status in the Overview section of the group's detail page.
