Test the connection for a StorageGRID platform services endpoint
If the connection to a platform service has changed, you can test the connection for the endpoint to validate that the destination resource exists and that it can be reached using the credentials you specified.
Before you begin
About this task
StorageGRID does not validate that the credentials have the correct permissions.
Steps
  1. Select STORAGE (S3) > Platform services endpoints.
    The Platform services endpoints page appears and shows the list of platform services endpoints that have already been configured.
  2. Select the endpoint whose connection you want to test.
    The endpoint details page appears.
  3. Select Test connection.
    • A success message appears if the endpoint can be reached using the specified credentials. The connection to the endpoint is validated from one node at each site.
    • An error message appears if endpoint validation fails. If you need to modify the endpoint to correct the error, select Configuration and update the information. Then, select Test and save changes.
