StorageGRID appliances
Replace a NIC in an SG110 or SG1100
Contributors netapp-perveilerk netapp-pcarriga
You might need to replace a Network Interface Card (NIC) in the SG110 or SG1100 if it is not functioning optimally or if it has failed.
Use these procedures to:
  • Remove the NIC
  • Reinstall the NIC
Remove the NIC
Before you begin
About this task
To prevent service interruptions, confirm that all other Storage Nodes are connected to the grid before starting the Network Interface Card (NIC) replacement or replace the NIC during a scheduled maintenance window when periods of service disruption are acceptable. See the information about monitoring node connection states.
Steps
  1. Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
  2. Locate the riser assembly that contains the NIC at the rear of the appliance.
    The three NICs in the appliance are in two riser assemblies in the positions in the chassis shown in the photograph (Rear of appliance with top cover removed shown):
    NIC locations
    Device or Part name Description
    1
    hic1/hic2
    10/25-GbE Ethernet network ports in the two-port riser assembly
    2
    mtc1/mtc2
    1/10GBase-T management ports in the two-port riser assembly
    3
    hic3/hic4
    10/25-GbE Ethernet network ports in the one-port riser assembly
    4
    Two-slot riser assembly
    Support for one of the 10/25-GbE NICs and the 1/10GBase-T NIC
    5
    One-slot riser assembly
  3. Grasp the riser assembly with the failed NIC through the blue-marked holes and carefully lift it upwards. Move the riser assembly toward the front of the chassis as you lift it to allow the external connectors in its installed NICs to clear the chassis.
  4. Place the riser on a flat anti-static surface with the metal frame side down to access the NICs.
    • Two-slot riser assembly with two NICs
      Two NICs in two-slot riser assembly
    • One-slot riser assembly with one NIC
      NIC in one-slot riser assembly
  5. Open the blue latch (circled) on the NIC to be replaced and carefully remove the NIC from the riser assembly. Rock the NIC slightly to help remove the NIC from its connector. Don't use excessive force.
  6. Place the NIC on a flat anti-static surface.
Reinstall the internal NIC
Install the replacement NIC into the same location as the one that was removed.
Before you begin
  • You have the correct replacement NIC.
  • You have removed the existing failed NIC.
Steps
  2. Remove the replacement NIC from its packaging.
  3. If you are replacing one of the NICs in the two-slot riser assembly, do the following:
    1. Ensure the blue latch is in the open position.
    2. Align the NIC with its connector on the riser assembly. Carefully press the NIC into the connector until it is fully seated, as shown in the photograph, and then close the blue latch.
    3. Locate the alignment hole on the two-slot riser assembly (circled) that aligns with a guide pin on the system board to ensure correct riser assembly positioning.
      Alignment hole on large riser assembly
    4. Locate the guide pin on the system board
      Guide pin for two-slot riser assembly
    5. Position the riser assembly in the chassis, making sure that it aligns with the connector on the system board and guide pin.
    6. Carefully press the two-slot riser assembly in place along its center line, next to the blue-marked holes, until it is fully seated.
  4. If you are replacing the NIC in the one-slot riser assembly, do the following:
    2. Align the NIC with its connector on the riser assembly. Carefully press the NIC into the connector until it is fully seated as shown in the photograph and close the blue latch.
    3. Locate the alignment hole on the one-slot riser assembly (circled) that aligns with a guide pin on the system board to ensure correct riser assembly positioning.
      Alignment hole on one-slot riser assembly
      Guide pin on one-slot riser assembly
    5. Position the one-slot riser assembly in the chassis, making sure that it aligns with the connector on the system board and guide pin.
    6. Carefully press the one-slot riser assembly in place along its center line, next to the blue-marked holes, until it is fully seated.
  5. Remove the protective caps from the NIC ports where you will be reinstalling cables.
After you finish
If you have no other maintenance procedures to perform in the appliance, reinstall the appliance cover, return the appliance to the rack, attach cables, and apply power.
After replacing the part, return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Parts Return & Replacements page for further information.
