StorageGRID appliances
Replace other hardware components in the SG5700
Contributors netapp-perveilerk netapp-pcarriga
You might need to replace a controller battery, drive, fan, or power supply, in the StorageGRID appliance.
Before you begin
  • You have the E-Series hardware replacement procedure.
  • The appliance has been placed into maintenance mode if the component replacement procedure requires that you shut down the appliance.
About this task
To replace the battery in the E2800 controller, see the instructions in these instructions for replacing the E2800 controller. Those instructions describe how to remove the controller from the appliance, remove the battery from the controller, install the battery, and replace the controller.
To replace a drive, power-fan canister, fan canister, power canister, or drive drawer in the appliance, access the E-Series procedures for maintaining E2800 hardware.
SG5712 component replacement instructions
SG5760 component replacement instructions
