Astra Trident
21.07
Prerequisites for deployment
You have to install and configure the necessary protocol prerequisites on your host before you can deploy Astra Trident.
  • Verify that your deployment meets all of the requirements.
  • Verify that you have a supported version of Docker installed. If your Docker version is out of date, install or update it.
docker --version
  • Verify that the protocol prerequisites are installed and configured on your host:
Protocol Operating system Commands
NFS
RHEL/CentOS
sudo yum install -y nfs-utils
NFS
Ubuntu/Debian
sudo apt-get install -y nfs-common
iSCSI
RHEL/CentOS
  1. Install the following system packages:
    sudo yum install -y lsscsi iscsi-initiator-utils sg3_utils device-mapper-multipath
  2. Start the multipathing daemon:
    sudo mpathconf --enable --with_multipathd y
  3. Ensure that iscsid and multipathd are enabled and running:
    sudo systemctl enable iscsid multipathd
    sudo systemctl start iscsid multipathd
  4. Discover the iSCSI targets:
    sudo iscsiadm -m discoverydb -t st -p <DATA_LIF_IP> --discover
  5. Log in to the discovered iSCSI targets:
    sudo iscsiadm -m node -p <DATA_LIF_IP> --login
  6. Enable and start iscsi:
iSCSI
Ubuntu/Debian
    sudo apt-get install -y open-iscsi lsscsi sg3-utils multipath-tools scsitools
  2. Enable multipathing:
    sudo tee /etc/multipath.conf <←'EOF'
    defaults {
    user_friendly_names yes
    find_multipaths yes
    EOF
    sudo service multipath-tools restart
  3. Ensure that iscsid and multipathd are running:
    sudo service open-iscsi start
    sudo service multipath-tools start
