Astra Trident REST API
Contributors juliantap
While tridentctl commands and options is the easiest way to interact with Astra Trident’s REST API, you can use the REST endpoint directly if you prefer.
This is useful for advanced installations that use Astra Trident as a standalone binary in non-Kubernetes deployments.
For better security, Astra Trident’s REST API is restricted to localhost by default when running inside a pod. To change this behavior, you need to set Astra Trident’s -address argument in its pod configuration.
The API works as follows:
GET
  • GET <trident-address>/trident/v1/<object-type>: Lists all objects of that type.
  • GET <trident-address>/trident/v1/<object-type>/<object-name>: Gets the details of the named object.
POST
POST <trident-address>/trident/v1/<object-type>: Creates an object of the specified type.
  • Requires a JSON configuration for the object to be created. For the specification of each object type, see tridentctl commands and options.
  • If the object already exists, behavior varies: backends update the existing object, while all other object types will fail the operation.
DELETE
DELETE <trident-address>/trident/v1/<object-type>/<object-name>: Deletes the named resource.
Note Volumes associated with backends or storage classes will continue to exist; these must be deleted separately. For more information, see tridentctl commands and options.
For examples of how these APIs are called, pass the debug (-d) flag. For more information, see tridentctl commands and options.
