Customize Trident operator deployment
The Trident operator allows you to customize Astra Trident installation using the attributes in the TridentOrchestrator spec.
If you want to customize the installation beyond what TridentOrchestrator arguments allow, you should consider using tridentctl to generate custom YAML manifests that you can modify as needed.
spec.namespace is specified in TridentOrchestrator to signify which namespace where Astra Trident is installed. This parameter cannot be updated after Astra Trident is installed. Attempting to do so causes the TridentOrchestrator status to change to Failed. Astra Trident is not intended to be migrated across namespaces.
Configuration options
This table details TridentOrchestrator attributes:
| Parameter | Description | Default |
Namespace to install Astra Trident in |
"default" |
Enable debugging for Astra Trident |
false |
Setting to |
false |
Install Astra Trident over IPv6 |
false |
Timeout for Kubernetes operations |
30sec |
Don't send autosupport bundles to NetApp |
false |
Manage worker node dependencies automatically (BETA) |
false |
The container image for Autosupport Telemetry |
"netapp/trident-autosupport:22.10.0" |
The address/port of a proxy for sending Autosupport |
"http://proxy.example.com:8888" |
A flag used to uninstall Astra Trident |
false |
Astra Trident logging format to be used [text,json] |
"text" |
Astra Trident image to install |
"netapp/trident:21.04" |
Path to internal registry, of the format |
"k8s.gcr.io/sig-storage (k8s 1.19+) |
Path to the kubelet directory on the host |
“/var/lib/kubelet” |
A list of resources to delete to perform a complete removal of |
Secrets to pull images from an internal registry |
Additional node selectors for pods running the Trident Controller CSI Plugin. Follows same format as pod.spec.nodeSelector. |
No default; optional |
Overrides tolerations for pods running the Trident Controller CSI Plugin. Follows the same format as pod.spec.Tolerations. |
Additional node selectors for pods running the Trident Node CSI Plugin. Follows same format as pod.spec.nodeSelector. |
Overrides tolerations for pods running the Trident Node CSI Plugin. Follows the same format as pod.spec.Tolerations. |
For more information on formatting pod parameters, see Assigning Pods to Nodes. |
Sample configurations
You can use the attributes mentioned above when defining TridentOrchestrator to customize your installation.
Example 1: Basic custom configuration
This is an example for a basic custom configuration.
cat deploy/crds/tridentorchestrator_cr_imagepullsecrets.yaml apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident imagePullSecrets: - thisisasecret
Example 2: Deploy with node selectors
This example illustrates how Trident can be deployed with node selectors:
metadata:
spec:
debug: true
namespace: trident
controllerPluginNodeSelector:
nodetype: master
nodePluginNodeSelector:
storage: netapp
Example 3: Deploy on Windows worker nodes
This example illustrates deployment on a Windows worker node.
$ cat deploy/crds/tridentorchestrator_cr.yaml apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident windows: true
