Prepare the worker node
All of the worker nodes in the Kubernetes cluster need to be able to mount the volumes that you have provisioned for your pods. If you are using the ontap-nas, ontap-nas-economy, or ontap-nas-flexgroup driver for one of your backends, your worker nodes need the NFS tools. Otherwise they require the iSCSI tools.
Recent versions of RedHat CoreOS have both NFS and iSCSI installed by default.
You should always reboot your worker nodes after installing the NFS or iSCSI tools, or else attaching volumes to containers might fail. |
Node service discovery
Beginning in 22.07, Astra Trident attempts to automatically detect if the node is capable of running iSCSI or NFS services. Astra Trident creates events for the node to identify the services discovered. You can review these events using the command:
kubectl get event -A --field-selector involvedObject.name=<Kubernetes node name>
Trident also identifies services enabled for each node on the Trident node CR. To view the discovered services, use the command:
tridentctl get node -o wide -n <Trident namespace>
Node service discovery identifies discovered services but does not guarantee services are properly configured. Conversely, the absence of a discovered service does not guarantee the volume mount will fail. |
NFS volumes
| Protocol | Operating system | Commands |
NFS |
RHEL/CentOS 7 |
NFS |
Ubuntu |
You should ensure that the NFS service is started up during boot time. |
iSCSI volumes
Consider the following when using iSCSI volumes:
Each node in the Kubernetes cluster must have a unique IQN. This is a necessary prerequisite.
If using RHCOS version 4.5 or later, or other RHEL-compatible Linux distribution, with the
solidfire-sandriver and Element OS 12.5 or earlier, ensure that the CHAP authentication algorithm is set to MD5 in/etc/iscsi/iscsid.conf. Secure FIPS-compliant CHAP algorithms SHA1, SHA-256, and SHA3-256 are available with Element 12.7.sudo sed -i 's/^\(node.session.auth.chap_algs\).*/\1 = MD5/' /etc/iscsi/iscsid.conf
When using worker nodes that run RHEL/RedHat CoreOS with iSCSI PVs, make sure to specify the
discardmountOption in the StorageClass to perform inline space reclamation. See RedHat’s documentation.
| Protocol | Operating system | Commands | ||
iSCSI |
RHEL/CentOS |
iSCSI |
Ubuntu |
For Ubuntu 18.04, you must discover target ports with iscsiadm before starting open-iscsi for the iSCSI daemon to start. You can alternatively modify the iscsi service to start iscsid automatically.
