Provision a volume
Contributors netapp-aruldeepa
Create a PersistentVolume (PV) and a PersistentVolumeClaim (PVC) that uses the configured Kubernetes StorageClass to request access to the PV. You can then mount the PV to a pod.
Overview
A PersistentVolume (PV) is a physical storage resource provisioned by the cluster administrator on a Kubernetes cluster. The PersistentVolumeClaim (PVC) is a request for access to the PersistentVolume on the cluster.
The PVC can be configured to request storage of a certain size or access mode. Using the associated StorageClass, the cluster administrator can control more than PersistentVolume size and access mode—​such as performance or service level.
After you create the PV and PVC, you can mount the volume in a pod.
Sample manifests
PersistentVolume sample manifest
This sample manifest shows a basic PV of 10Gi that is associated with StorageClass basic-csi.
apiVersion: v1
kind: PersistentVolume
metadata:
  labels:
    type: local
spec:
  storageClassName: basic-csi
  capacity:
    storage: 10Gi
  accessModes:
    - ReadWriteOnce
  hostPath:
    path: "/my/host/path"
PersistentVolumeClaim sample manifests
These examples show basic PVC configuration options.
PVC with RWO access
This example shows a basic PVC with RWO access that is associated with a StorageClass named basic-csi.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
PVC with NVMe/TCP
This example shows a basic PVC for NVMe/TCP with RWO access that is associated with a StorageClass named protection-gold.
apiVersion: v1
metadata:
spec:
accessModes:
  - ReadWriteOnce
resources:
  requests:
    storage: 300Mi
storageClassName: protection-gold
Pod manifest samples
These examples show basic configurations to attach the PVC to a pod.
Basic configuration
kind: Pod
apiVersion: v1
metadata:
spec:
  volumes:
    - name: pv-storage
      persistentVolumeClaim:
       claimName: basic
  containers:
    - name: pv-container
      image: nginx
      ports:
        - containerPort: 80
      volumeMounts:
        - mountPath: "/my/mount/path"
Basic NVMe/TCP configuration
apiVersion: v1
kind: Pod
metadata:
  creationTimestamp: null
  labels:
    run: nginx
spec:
  containers:
    - image: nginx
      resources: {}
      volumeMounts:
        - mountPath: "/usr/share/nginx/html"
  dnsPolicy: ClusterFirst
  restartPolicy: Always
  volumes:
    - name: task-pv-storage
      claimName: pvc-san-nvme
Create the PV and PVC
Steps
  1. Create the PV.
    kubectl create -f pv.yaml
  2. Verify the PV status.
    kubectl get pv
    NAME        CAPACITY  ACCESS MODES  RECLAIM POLICY  STATUS    CLAIM  STORAGECLASS  REASON  AGE
    pv-storage  4Gi       RWO           Retain          Available                              7s
  3. Create the PVC.
    kubectl create -f pvc.yaml
  4. Verify the PVC status.
    kubectl get pvc
    NAME        STATUS VOLUME     CAPACITY ACCESS MODES STORAGECLASS AGE
    pvc-storage Bound  pv-name 2Gi      RWO                       5m
  5. Mount the volume in a pod.
    kubectl create -f pv-pod.yaml
    Note You can monitor the progress using kubectl get pod --watch.
  6. Verify that the volume is mounted on /my/mount/path.
    kubectl exec -it task-pv-pod -- df -h /my/mount/path
  7. You can now delete the Pod. The Pod application will no longer exist, but the volume will remain.
    kubectl delete pod task-pv-pod
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Astra Trident provisions volumes.
