Provision a volume
Create a PersistentVolume (PV) and a PersistentVolumeClaim (PVC) that uses the configured Kubernetes StorageClass to request access to the PV. You can then mount the PV to a pod.
Overview
A PersistentVolume (PV) is a physical storage resource provisioned by the cluster administrator on a Kubernetes cluster. The PersistentVolumeClaim (PVC) is a request for access to the PersistentVolume on the cluster.
The PVC can be configured to request storage of a certain size or access mode. Using the associated StorageClass, the cluster administrator can control more than PersistentVolume size and access mode—such as performance or service level.
After you create the PV and PVC, you can mount the volume in a pod.
Sample manifests
PersistentVolume sample manifest
This sample manifest shows a basic PV of 10Gi that is associated with StorageClass basic-csi.
apiVersion: v1
kind: PersistentVolume
metadata:
labels:
type: local
spec:
storageClassName: basic-csi
capacity:
storage: 10Gi
accessModes:
- ReadWriteOnce
hostPath:
path: "/my/host/path"
PersistentVolumeClaim sample manifests
These examples show basic PVC configuration options.
This example shows a basic PVC with RWO access that is associated with a StorageClass named basic-csi.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
This example shows a basic PVC for NVMe/TCP with RWO access that is associated with a StorageClass named protection-gold.
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 300Mi
storageClassName: protection-gold
Pod manifest samples
These examples show basic configurations to attach the PVC to a pod.
kind: Pod
apiVersion: v1
metadata:
spec:
volumes:
- name: pv-storage
persistentVolumeClaim:
claimName: basic
containers:
- name: pv-container
image: nginx
ports:
- containerPort: 80
volumeMounts:
- mountPath: "/my/mount/path"
apiVersion: v1
kind: Pod
metadata:
creationTimestamp: null
labels:
run: nginx
spec:
containers:
- image: nginx
resources: {}
volumeMounts:
- mountPath: "/usr/share/nginx/html"
dnsPolicy: ClusterFirst
restartPolicy: Always
volumes:
- name: task-pv-storage
claimName: pvc-san-nvme
Create the PV and PVC
Create the PV.
kubectl create -f pv.yaml
Verify the PV status.
kubectl get pv NAME CAPACITY ACCESS MODES RECLAIM POLICY STATUS CLAIM STORAGECLASS REASON AGE pv-storage 4Gi RWO Retain Available 7s
Create the PVC.
kubectl create -f pvc.yaml
Verify the PVC status.
kubectl get pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE pvc-storage Bound pv-name 2Gi RWO 5m
Mount the volume in a pod.
kubectl create -f pv-pod.yaml
You can monitor the progress using kubectl get pod --watch. -
Verify that the volume is mounted on
/my/mount/path.kubectl exec -it task-pv-pod -- df -h /my/mount/path
You can now delete the Pod. The Pod application will no longer exist, but the volume will remain.
kubectl delete pod task-pv-pod
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Astra Trident provisions volumes.
