Provision a Trident volume
Create a PersistentVolumeClaim (PVC) that uses the configured Kubernetes StorageClass to request access to the PV. You can then mount the PV to a pod.
Overview
A PersistentVolumeClaim (PVC) is a request for access to the PersistentVolume on the cluster.
The PVC can be configured to request storage of a certain size or access mode. Using the associated StorageClass, the cluster administrator can control more than PersistentVolume size and access mode—​such as performance or service level.
After you create the PVC you can mount the volume in a pod.
Create the PVC
Steps
  1. Create the PVC.
    kubectl create -f pvc.yaml
  2. Verify the PVC status.
    kubectl get pvc
NAME        STATUS  VOLUME     CAPACITY   ACCESS MODES  STORAGECLASS AGE
pvc-storage Bound   pv-name    1Gi        RWO                  5m
  1. Mount the volume in a pod.
    kubectl create -f pv-pod.yaml
    Note You can monitor the progress using kubectl get pod --watch.
  2. Verify that the volume is mounted on /my/mount/path.
    kubectl exec -it task-pv-pod -- df -h /my/mount/path
  3. You can now delete the Pod. The Pod application will no longer exist, but the volume will remain.
    kubectl delete pod pv-pod
Sample manifests
PersistentVolumeClaim sample manifests
These examples show basic PVC configuration options.
PVC with RWO access
This example shows a basic PVC with RWO access that is associated with a StorageClass named basic-csi.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
  storageClassName: basic-csi
PVC with NVMe/TCP
This example shows a basic PVC for NVMe/TCP with RWO access that is associated with a StorageClass named protection-gold.
apiVersion: v1
metadata:
spec:
accessModes:
  - ReadWriteOnce
resources:
  requests:
    storage: 300Mi
storageClassName: protection-gold
Pod manifest samples
These examples show basic configurations to attach the PVC to a pod.
Basic configuration
kind: Pod
apiVersion: v1
metadata:
spec:
  volumes:
    - name: storage
      persistentVolumeClaim:
       claimName: pvc-storage
  containers:
    - name: pv-container
      image: nginx
      ports:
        - containerPort: 80
      volumeMounts:
        - mountPath: "/my/mount/path"
Basic NVMe/TCP configuration
apiVersion: v1
kind: Pod
metadata:
spec:
  volumes:
    - name: basic-pvc
        claimName: pvc-san-nvme
  containers:
    - name: task-pv-container
      image: nginx
      volumeMounts:
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Trident provisions volumes.
