Work with snapshots
Kubernetes volume snapshots of Persistent Volumes (PVs) enable point-in-time copies of volumes. You can create a snapshot of a volume created using Astra Trident, import a snapshot created outside of Astra Trident, create a new volume from an existing snapshot, and recover volume data from snapshots.
Overview
Volume snapshot is supported by ontap-nas
, ontap-nas-flexgroup
, ontap-san
, ontap-san-economy
, solidfire-san
, gcp-cvs
, and azure-netapp-files
drivers.
You must have an external snapshot controller and Custom Resource Definitions (CRDs) to work with snapshots. This is the responsibility of the Kubernetes orchestrator (for example: Kubeadm, GKE, OpenShift).
If your Kubernetes distribution does not include the snapshot controller and CRDs, refer to Deploy a volume snapshot controller.
Don't create a snapshot controller if creating on-demand volume snapshots in a GKE environment. GKE uses a built-in, hidden snapshot controller. |
Create a volume snapshot
Create a
VolumeSnapshotClass
. For more information, refer to VolumeSnapshotClass.-
The
driver
points to the Astra Trident CSI driver. -
deletionPolicy
can beDelete
orRetain
. When set toRetain
, the underlying physical snapshot on the storage cluster is retained even when theVolumeSnapshot
object is deleted.Examplecat snap-sc.yaml apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshotClass metadata: name: csi-snapclass driver: csi.trident.netapp.io deletionPolicy: Delete
Create a snapshot of an existing PVC.
Examples-
This example creates a snapshot of an existing PVC.
cat snap.yaml apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshot metadata: name: pvc1-snap spec: volumeSnapshotClassName: csi-snapclass source: persistentVolumeClaimName: pvc1
This example creates a volume snapshot object for a PVC named
pvc1
and the name of the snapshot is set topvc1-snap
. A VolumeSnapshot is analogous to a PVC and is associated with aVolumeSnapshotContent
object that represents the actual snapshot.kubectl create -f snap.yaml volumesnapshot.snapshot.storage.k8s.io/pvc1-snap created kubectl get volumesnapshots NAME AGE pvc1-snap 50s
You can identify the
object for thepvc1-snap
VolumeSnapshot by describing it. TheSnapshot Content Name
identifies the VolumeSnapshotContent object which serves this snapshot. TheReady To Use
parameter indicates that the snapshot can be used to create a new PVC.kubectl describe volumesnapshots pvc1-snap Name: pvc1-snap Namespace: default . . . Spec: Snapshot Class Name: pvc1-snap Snapshot Content Name: snapcontent-e8d8a0ca-9826-11e9-9807-525400f3f660 Source: API Group: Kind: PersistentVolumeClaim Name: pvc1 Status: Creation Time: 2019-06-26T15:27:29Z Ready To Use: true Restore Size: 3Gi . .
Create a PVC from a volume snapshot
You can use dataSource
to create a PVC using a VolumeSnapshot named <pvc-name>
as the source of the data. After the PVC is created, it can be attached to a pod and used just like any other PVC.
The PVC will be created in the same backend as the source volume. Refer to KB: Creating a PVC from a Trident PVC Snapshot cannot be created in an alternate backend. |
The following example creates the PVC using pvc1-snap
as the data source.
cat pvc-from-snap.yaml apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-from-snap spec: accessModes: - ReadWriteOnce storageClassName: golden resources: requests: storage: 3Gi dataSource: name: pvc1-snap kind: VolumeSnapshot apiGroup: snapshot.storage.k8s.io
Import a volume snapshot
Astra Trident supports the Kubernetes pre-provisioned snapshot process to enable the cluster administrator to create a VolumeSnapshotContent
object and import snapshots created outside of Astra Trident.
Astra Trident must have created or imported the snapshot's parent volume.
Cluster admin: Create a
object that references the backend snapshot. This initiates the snapshot workflow in Astra Trident.-
Specify the name of the backend snapshot in
annotations
astrident.netapp.io/internalSnapshotName: <"backend-snapshot-name">
Specify
<name-of-parent-volume-in-trident>/<volume-snapshot-content-name>
insnapshotHandle
. This is the only information provided to Astra Trident by the external snapshotter in theListSnapshots
call.The <volumeSnapshotContentName>
cannot always match the backend snapshot name due to CR naming constraints.ExampleThe following example creates a
object that references backend snapshotsnap-01
.apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshotContent metadata: name: import-snap-content annotations: trident.netapp.io/internalSnapshotName: "snap-01" # This is the name of the snapshot on the backend spec: deletionPolicy: Retain driver: csi.trident.netapp.io source: snapshotHandle: pvc-f71223b5-23b9-4235-bbfe-e269ac7b84b0/import-snap-content # <import PV name or source PV name>/<volume-snapshot-content-name>
Cluster admin: Create the
VolumeSnapshot
CR that references theVolumeSnapshotContent
object. This requests access to use theVolumeSnapshot
in a given namespace.ExampleThe following example creates a
VolumeSnapshot
CR namedimport-snap
namedimport-snap-content
.apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshot metadata: name: import-snap spec: # volumeSnapshotClassName: csi-snapclass (not required for pre-provisioned or imported snapshots) source: volumeSnapshotContentName: import-snap-content
Internal processing (no action required): The external snapshotter recognizes the newly created
and runs theListSnapshots
call. Astra Trident creates theTridentSnapshot
The external snapshotter sets the
toreadyToUse
and theVolumeSnapshot
totrue
Trident returns
readyToUse=true
Any user: Create a
to reference the newVolumeSnapshot
, where thespec.dataSource
(orspec.dataSourceRef
) name is theVolumeSnapshot
name.ExampleThe following example creates a PVC referencing the
VolumeSnapshot
namedimport-snap
.apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-from-snap spec: accessModes: - ReadWriteOnce storageClassName: simple-sc resources: requests: storage: 1Gi dataSource: name: import-snap kind: VolumeSnapshot apiGroup: snapshot.storage.k8s.io
Recover volume data using snapshots
The snapshot directory is hidden by default to facilitate maximum compatibility of volumes provisioned using the ontap-nas
and ontap-nas-economy
drivers. Enable the .snapshot
directory to recover data from snapshots directly.
Use the volume snapshot restore ONTAP CLI to to restore a volume to a state recorded in a prior snapshot.
cluster1::*> volume snapshot restore -vserver vs0 -volume vol3 -snapshot vol3_snap_archive
When you restore a snapshot copy, the existing volume configuration is overwritten. Changes made to volume data after the snapshot copy was created are lost. |
Delete a PV with associated snapshots
When deleting a Persistent Volume with associated snapshots, the corresponding Trident volume is updated to a “Deleting state”. Remove the volume snapshots to delete the Astra Trident volume.
If your Kubernetes distribution does not include the snapshot controller and CRDs, you can deploy them as follows.
Create volume snapshot CRDs.
cat snapshot-setup.sh #!/bin/bash # Create volume snapshot CRDs kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotclasses.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotcontents.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshots.yaml
Create the snapshot controller.
kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/rbac-snapshot-controller.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/setup-snapshot-controller.yaml
If necessary, open deploy/kubernetes/snapshot-controller/rbac-snapshot-controller.yaml
and updatenamespace
to your namespace.
