Work with Trident snapshots
Kubernetes volume snapshots of Persistent Volumes (PVs) enable point-in-time copies of volumes. You can create a snapshot of a volume created using Trident, import a snapshot created outside of Trident, create a new volume from an existing snapshot, and recover volume data from snapshots.
Overview
Volume snapshot is supported by ontap-nas, ontap-nas-flexgroup, ontap-san, ontap-san-economy, solidfire-san, azure-netapp-files, and google-cloud-netapp-volumes drivers.
You must have an external snapshot controller and Custom Resource Definitions (CRDs) to work with snapshots. This is the responsibility of the Kubernetes orchestrator (for example: Kubeadm, GKE, OpenShift).
If your Kubernetes distribution does not include the snapshot controller and CRDs, refer to Deploy a volume snapshot controller.
Don't create a snapshot controller if creating on-demand volume snapshots in a GKE environment. GKE uses a built-in, hidden snapshot controller. |
Create a volume snapshot
Create a
VolumeSnapshotClass. For more information, refer to VolumeSnapshotClass.-
The
driverpoints to the Trident CSI driver. -
deletionPolicycan beDeleteorRetain. When set toRetain, the underlying physical snapshot on the storage cluster is retained even when theVolumeSnapshotobject is deleted.Examplecat snap-sc.yaml
apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshotClass metadata: name: csi-snapclass driver: csi.trident.netapp.io deletionPolicy: Delete
Create a snapshot of an existing PVC.
Examples-
This example creates a snapshot of an existing PVC.
cat snap.yaml
apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshot metadata: name: pvc1-snap spec: volumeSnapshotClassName: csi-snapclass source: persistentVolumeClaimName: pvc1 -
This example creates a volume snapshot object for a PVC named
pvc1and the name of the snapshot is set topvc1-snap. A VolumeSnapshot is analogous to a PVC and is associated with aVolumeSnapshotContentobject that represents the actual snapshot.kubectl create -f snap.yaml volumesnapshot.snapshot.storage.k8s.io/pvc1-snap created kubectl get volumesnapshots NAME AGE pvc1-snap 50s
You can identify the
VolumeSnapshotContentobject for thepvc1-snapVolumeSnapshot by describing it. TheSnapshot Content Nameidentifies the VolumeSnapshotContent object which serves this snapshot. TheReady To Useparameter indicates that the snapshot can be used to create a new PVC.kubectl describe volumesnapshots pvc1-snap Name: pvc1-snap Namespace: default ... Spec: Snapshot Class Name: pvc1-snap Snapshot Content Name: snapcontent-e8d8a0ca-9826-11e9-9807-525400f3f660 Source: API Group: Kind: PersistentVolumeClaim Name: pvc1 Status: Creation Time: 2019-06-26T15:27:29Z Ready To Use: true Restore Size: 3Gi ...
Create a PVC from a volume snapshot
You can use dataSource to create a PVC using a VolumeSnapshot named <pvc-name> as the source of the data. After the PVC is created, it can be attached to a pod and used just like any other PVC.
The PVC will be created in the same backend as the source volume. Refer to KB: Creating a PVC from a Trident PVC Snapshot cannot be created in an alternate backend. |
The following example creates the PVC using pvc1-snap as the data source.
cat pvc-from-snap.yaml
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
storageClassName: golden
resources:
requests:
storage: 3Gi
dataSource:
apiGroup: snapshot.storage.k8s.io
Import a volume snapshot
Trident supports the Kubernetes pre-provisioned snapshot process to enable the cluster administrator to create a VolumeSnapshotContent object and import snapshots created outside of Trident.
Trident must have created or imported the snapshot's parent volume.
Cluster admin: Create a
VolumeSnapshotContentobject that references the backend snapshot. This initiates the snapshot workflow in Trident.-
Specify the name of the backend snapshot in
annotationsastrident.netapp.io/internalSnapshotName: <"backend-snapshot-name">. -
Specify
<name-of-parent-volume-in-trident>/<volume-snapshot-content-name>insnapshotHandle. This is the only information provided to Trident by the external snapshotter in theListSnapshotscall.The <volumeSnapshotContentName>cannot always match the backend snapshot name due to CR naming constraints.ExampleThe following example creates a
VolumeSnapshotContentobject that references backend snapshotsnap-01.apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshotContent metadata: name: import-snap-content annotations: trident.netapp.io/internalSnapshotName: "snap-01" # This is the name of the snapshot on the backend spec: deletionPolicy: Retain driver: csi.trident.netapp.io source: snapshotHandle: pvc-f71223b5-23b9-4235-bbfe-e269ac7b84b0/import-snap-content # <import PV name or source PV name>/<volume-snapshot-content-name> volumeSnapshotRef: name: import-snap namespace: default
Cluster admin: Create the
VolumeSnapshotCR that references theVolumeSnapshotContentobject. This requests access to use theVolumeSnapshotin a given namespace.ExampleThe following example creates a
VolumeSnapshotCR namedimport-snapthat references theVolumeSnapshotContentnamedimport-snap-content.apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshot metadata: name: import-snap spec: # volumeSnapshotClassName: csi-snapclass (not required for pre-provisioned or imported snapshots) source: volumeSnapshotContentName: import-snap-content -
Internal processing (no action required): The external snapshotter recognizes the newly created
VolumeSnapshotContentand runs theListSnapshotscall. Trident creates theTridentSnapshot.-
The external snapshotter sets the
VolumeSnapshotContenttoreadyToUseand theVolumeSnapshottotrue. -
Trident returns
readyToUse=true.
Any user: Create a
PersistentVolumeClaimto reference the newVolumeSnapshot, where thespec.dataSource(orspec.dataSourceRef) name is theVolumeSnapshotname.ExampleThe following example creates a PVC referencing the
VolumeSnapshotnamedimport-snap.apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-from-snap spec: accessModes: - ReadWriteOnce storageClassName: simple-sc resources: requests: storage: 1Gi dataSource: name: import-snap kind: VolumeSnapshot apiGroup: snapshot.storage.k8s.io
Recover volume data using snapshots
The snapshot directory is hidden by default to facilitate maximum compatibility of volumes provisioned using the ontap-nas and ontap-nas-economy drivers. Enable the .snapshot directory to recover data from snapshots directly.
Use the volume snapshot restore ONTAP CLI to to restore a volume to a state recorded in a prior snapshot.
cluster1::*> volume snapshot restore -vserver vs0 -volume vol3 -snapshot vol3_snap_archive
When you restore a snapshot copy, the existing volume configuration is overwritten. Changes made to volume data after the snapshot copy was created are lost. |
In-place volume restoration from a snapshot
Trident provides rapid, in-place volume restoration from a snapshot using the TridentActionSnapshotRestore (TASR) CR. This CR functions as an imperative Kubernetes action and does not persist after the operation completes.
Trident supports snapshot restore on the ontap-san, ontap-san-economy, ontap-nas, ontap-nas-flexgroup, azure-netapp-files, google-cloud-netapp-volumes, and solidfire-san drivers.
You must have a bound PVC and available volume snapshot.
Verify the PVC status is bound.
kubectl get pvc -
Verify the volume snapshot is ready to use.
kubectl get vs
Create the TASR CR. This example creates a CR for PVC
pvc1and volume snapshotpvc1-snapshot.The TASR CR must be in a namespace where the PVC & VS exist. cat tasr-pvc1-snapshot.yamlapiVersion: trident.netapp.io/v1 kind: TridentActionSnapshotRestore metadata: name: trident-snap namespace: trident spec: pvcName: pvc1 volumeSnapshotName: pvc1-snapshot -
Apply the CR to restore from the snapshot. This example restores from snapshot
pvc1.kubectl create -f tasr-pvc1-snapshot.yamltridentactionsnapshotrestore.trident.netapp.io/trident-snap created
Trident restores the data from the snapshot. You can verify the snapshot restore status:
kubectl get tasr -o yaml
items:
- apiVersion: trident.netapp.io/v1
metadata:
creationTimestamp: "2023-04-14T00:20:33Z"
generation: 3
namespace: trident
resourceVersion: "3453847"
uid: <uid>
spec:
pvcName: pvc1
status:
startTime: "2023-04-14T00:20:34Z"
completionTime: "2023-04-14T00:20:37Z"
state: Succeeded
kind: List
metadata:
resourceVersion: ""
Delete a PV with associated snapshots
When deleting a Persistent Volume with associated snapshots, the corresponding Trident volume is updated to a "Deleting state". Remove the volume snapshots to delete the Trident volume.
If your Kubernetes distribution does not include the snapshot controller and CRDs, you can deploy them as follows.
Create volume snapshot CRDs.
cat snapshot-setup.sh
#!/bin/bash # Create volume snapshot CRDs kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotclasses.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotcontents.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshots.yaml -
Create the snapshot controller.
kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/rbac-snapshot-controller.yamlkubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/setup-snapshot-controller.yamlIf necessary, open deploy/kubernetes/snapshot-controller/rbac-snapshot-controller.yamland updatenamespaceto your namespace.
