Work with snapshots
You can create Kubernetes VolumeSnapshots (volume snapshot) of Persistent Volumes (PVs) to maintain point-in-time copies of Astra Trident volumes. Additionally, you can create a new volume, also known as a clone, from an existing volume snapshot. Volume snapshot is supported by ontap-nas, ontap-nas-flexgroup, ontap-san, ontap-san-economy, solidfire-san, gcp-cvs, and azure-netapp-files drivers.
You must have an external snapshot controller and Custom Resource Definitions (CRDs). This is the responsibility of the Kubernetes orchestrator (for example: Kubeadm, GKE, OpenShift).
If your Kubernetes distribution does not include the snapshot controller and CRDs, refer to Deploying a volume snapshot controller.
Don’t create a snapshot controller if creating on-demand volume snapshots in a GKE environment. GKE uses a built-in, hidden snapshot controller. |
Step 1: Create a VolumeSnapshotClass
This example creates a volume snapshot class.
cat snap-sc.yaml apiVersion: snapshot.storage.k8s.io/v1 kind: VolumeSnapshotClass metadata: name: csi-snapclass driver: csi.trident.netapp.io deletionPolicy: Delete
The driver points to Astra Trident’s CSI driver. deletionPolicy can be Delete or Retain. When set to Retain, the underlying physical snapshot on the storage cluster is retained even when the VolumeSnapshot object is deleted.
For more information, refer to VolumeSnapshotClass.
Step 2: Create a snapshot of an existing PVC
This example creates a snapshot of an existing PVC.
cat snap.yaml
metadata:
spec:
volumeSnapshotClassName: csi-snapclass
source:
persistentVolumeClaimName: pvc1
In this example, the snapshot is created for a PVC named pvc1 and the name of the snapshot is set to pvc1-snap.
kubectl create -f snap.yaml volumesnapshot.snapshot.storage.k8s.io/pvc1-snap created kubectl get volumesnapshots NAME AGE pvc1-snap 50s
This created a VolumeSnapshot object. A VolumeSnapshot is analogous to a PVC and is associated with a VolumeSnapshotContent object that represents the actual snapshot.
It is possible to identify the VolumeSnapshotContent object for the pvc1-snap VolumeSnapshot by describing it.
kubectl describe volumesnapshots pvc1-snap
Namespace: default
Spec:
Snapshot Class Name: pvc1-snap
Snapshot Content Name: snapcontent-e8d8a0ca-9826-11e9-9807-525400f3f660
Source:
API Group:
Kind: PersistentVolumeClaim
Status:
Creation Time: 2019-06-26T15:27:29Z
Ready To Use: true
Restore Size: 3Gi
The Snapshot Content Name identifies the VolumeSnapshotContent object which serves this snapshot. The Ready To Use parameter indicates that the Snapshot can be used to create a new PVC.
Step 3: Create PVCs from VolumeSnapshots
This example creates a PVC using a snapshot:
cat pvc-from-snap.yaml
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
storageClassName: golden
resources:
requests:
storage: 3Gi
dataSource:
apiGroup: snapshot.storage.k8s.io
dataSource shows that the PVC must be created using a VolumeSnapshot named pvc1-snap as the source of the data. This instructs Astra Trident to create a PVC from the snapshot. After the PVC is created, it can be attached to a pod and used just like any other PVC.
When deleting a Persistent Volume with associated snapshots, the corresponding Trident volume is updated to a “Deleting state”. For the Astra Trident volume to be deleted, the snapshots of the volume should be removed. |
If your Kubernetes distribution does not include the snapshot controller and CRDs, you can deploy them as follows.
Create volume snapshot CRDs.
cat snapshot-setup.sh #!/bin/bash # Create volume snapshot CRDs kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotclasses.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshotcontents.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/client/config/crd/snapshot.storage.k8s.io_volumesnapshots.yaml
Create the snapshot controller in the desired namespace. Edit the YAML manifests below to modify namespace.
kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/rbac-snapshot-controller.yaml kubectl apply -f https://raw.githubusercontent.com/kubernetes-csi/external-snapshotter/release-6.1/deploy/kubernetes/snapshot-controller/setup-snapshot-controller.yaml
