Upgrade or uninstall Astra Trident
You can safely upgrade Astra Trident for Docker without any impact to volumes that are in use. During the upgrade process there will be a brief period where docker volume commands directed at the plugin will not succeed, and applications will be unable to mount volumes until the plugin is running again. Under most circumstances, this is a matter of seconds.
Upgrade
Perform the steps below to upgrade Astra Trident for Docker.
Steps
List the existing volumes:
docker volume ls DRIVER VOLUME NAME netapp:latest my_volume
Disable the plugin:
docker plugin disable -f netapp:latest docker plugin ls ID NAME DESCRIPTION ENABLED 7067f39a5df5 netapp:latest nDVP - NetApp Docker Volume Plugin false
Upgrade the plugin:
docker plugin upgrade --skip-remote-check --grant-all-permissions netapp:latest netapp/trident-plugin:21.07
The 18.01 release of Astra Trident replaces the nDVP. You should upgrade directly from the netapp/ndvp-pluginimage to thenetapp/trident-pluginimage. -
Enable the plugin:
docker plugin enable netapp:latest
Verify that the plugin is enabled:
docker plugin ls ID NAME DESCRIPTION ENABLED 7067f39a5df5 netapp:latest Trident - NetApp Docker Volume Plugin true
Verify that the volumes are visible:
If you are upgrading from an old version of Astra Trident (pre-20.10) to Astra Trident 20.10 or later, you might run into an error. For more information, refer to Known Issues. If you run into the error, you should first disable the plugin, then remove the plugin, and then install the required Astra Trident version by passing an extra config parameter: docker plugin install netapp/trident-plugin:20.10 --alias netapp --grant-all-permissions config=config.json
Uninstall
Perform the steps below to uninstall Astra Trident for Docker.
Steps
Remove any volumes that the plugin created.
Disable the plugin:
docker plugin disable netapp:latest docker plugin ls ID NAME DESCRIPTION ENABLED 7067f39a5df5 netapp:latest nDVP - NetApp Docker Volume Plugin false
Remove the plugin:
docker plugin rm netapp:latest
