ONTAP SAN driver overview
Learn about configuring an ONTAP backend with ONTAP and Cloud Volumes ONTAP SAN drivers.
ONTAP SAN driver details
Astra Trident provides the following SAN storage drivers to communicate with the ONTAP cluster. Supported access modes are: ReadWriteOnce (RWO), ReadOnlyMany (ROX), ReadWriteMany (RWX), ReadWriteOncePod (RWOP).
If you are using Astra Control for protection, recovery, and mobility, read Astra Control driver compatibility. |
| Driver | Protocol | volumeMode | Access modes supported | File systems supported |
iSCSI |
Block |
RWO, ROX, RWX, RWOP |
No filesystem; raw block device |
iSCSI |
Filesystem |
RWO, RWOP ROX and RWX are not available in Filesystem volume mode. |
NVMe/TCP Refer to Additional considerations for NVMe/TCP. |
Block |
Filesystem |
iSCSI |
Block |
iSCSI |
Filesystem |
Astra Control provides seamless protection, disaster recovery, and mobility (moving volumes between Kubernetes clusters) for volumes created with the ontap-nas, ontap-nas-flexgroup, and ontap-san drivers. Refer to Astra Control replication prerequisites for details.
User permissions
Astra Trident expects to be run as either an ONTAP or SVM administrator, typically using the admin cluster user or a vsadmin SVM user, or a user with a different name that has the same role. For Amazon FSx for NetApp ONTAP deployments, Astra Trident expects to be run as either an ONTAP or SVM administrator, using the cluster fsxadmin user or a vsadmin SVM user, or a user with a different name that has the same role. The fsxadmin user is a limited replacement for the cluster admin user.
If you use the limitAggregateUsage parameter, cluster admin permissions are required. When using Amazon FSx for NetApp ONTAP with Astra Trident, the limitAggregateUsage parameter will not work with the vsadmin and fsxadmin user accounts. The configuration operation will fail if you specify this parameter.
While it is possible to create a more restrictive role within ONTAP that a Trident driver can use, we don't recommend it. Most new releases of Trident will call additional APIs that would have to be accounted for, making upgrades difficult and error-prone.
Astra Trident supports the non-volatile memory express (NVMe) protocol using the ontap-san driver including:
IPv6
Snapshots and clones of NVMe volumes
Resizing an NVMe volume
Importing an NVMe volume that was created outside of Astra Trident so that its lifecycle can be managed by Astra Trident
NVMe-native multipathing
Graceful or ungraceful shutdown of the K8s nodes (24.02)
Astra Trident does not support:
DH-HMAC-CHAP that is supported by natively by NVMe
Device mapper (DM) multipathing
LUKS encryption
