ONTAP SAN driver overview
Contributors netapp-aruldeepa
Learn about configuring an ONTAP backend with ONTAP and Cloud Volumes ONTAP SAN drivers.
ONTAP SAN driver details
Trident provides the following SAN storage drivers to communicate with the ONTAP cluster. Supported access modes are: ReadWriteOnce (RWO), ReadOnlyMany (ROX), ReadWriteMany (RWX), ReadWriteOncePod (RWOP).
Driver Protocol volumeMode Access modes supported File systems supported
ontap-san
iSCSI
SCSI over FC (tech preview in Trident 24.10)
Block
RWO, ROX, RWX, RWOP
No filesystem; raw block device
ontap-san
iSCSI
Filesystem
RWO, RWOP
ROX and RWX are not available in Filesystem volume mode.
xfs, ext3, ext4
ontap-san
Block
RWO, ROX, RWX, RWOP
ontap-san
Filesystem
RWO, RWOP
xfs, ext3, ext4
ontap-san-economy
iSCSI
Block
RWO, ROX, RWX, RWOP
ontap-san-economy
iSCSI
Filesystem
RWO, RWOP
xfs, ext3, ext4
Warning
  • Use ontap-san-economy only if persistent volume usage count is expected to be higher than supported ONTAP volume limits.
  • Use ontap-nas-economy only if persistent volume usage count is expected to be higher than supported ONTAP volume limits and the ontap-san-economy driver cannot be used.
  • Do not use use ontap-nas-economy if you anticipate the need for data protection, disaster recovery, or mobility.
User permissions
Trident expects to be run as either an ONTAP or SVM administrator, typically using the admin cluster user or a vsadmin SVM user, or a user with a different name that has the same role. For Amazon FSx for NetApp ONTAP deployments, Trident expects to be run as either an ONTAP or SVM administrator, using the cluster fsxadmin user or a vsadmin SVM user, or a user with a different name that has the same role. The fsxadmin user is a limited replacement for the cluster admin user.
Note If you use the limitAggregateUsage parameter, cluster admin permissions are required. When using Amazon FSx for NetApp ONTAP with Trident, the limitAggregateUsage parameter will not work with the vsadmin and fsxadmin user accounts. The configuration operation will fail if you specify this parameter.
While it is possible to create a more restrictive role within ONTAP that a Trident driver can use, we don't recommend it. Most new releases of Trident will call additional APIs that would have to be accounted for, making upgrades difficult and error-prone.
Additional considerations for NVMe/TCP
Trident supports the non-volatile memory express (NVMe) protocol using the ontap-san driver including:
  • IPv6
  • Snapshots and clones of NVMe volumes
  • Resizing an NVMe volume
  • Importing an NVMe volume that was created outside of Trident so that its lifecycle can be managed by Trident
  • NVMe-native multipathing
  • Graceful or ungraceful shutdown of the K8s nodes (24.06)
Trident does not support:
  • DH-HMAC-CHAP that is supported by natively by NVMe
  • Device mapper (DM) multipathing
  • LUKS encryption
