Import volumes
You can import existing storage volumes as a Kubernetes PV using tridentctl import
Overview and considerations
You might import a volume into Astra Trident to:
Containerize an application and reuse its existing data set
Use a clone of a data set for an ephemeral application
Rebuild a failed Kubernetes cluster
Migrate application data during disaster recovery
Before importing a volume, review the following considerations.
Astra Trident can import RW (read-write) type ONTAP volumes only. DP (data protection) type volumes are SnapMirror destination volumes. You should break the mirror relationship before importing the volume into Astra Trident.
We suggest importing volumes without active connections. To import an actively-used volume, clone the volume and then perform the import.
This is especially important for block volumes as Kubernetes would be unaware of the previous connection and could easily attach an active volume to a pod. This can result in data corruption. -
Though
StorageClass
must be specified on a PVC, Astra Trident does not use this parameter during import. Storage classes are used during volume creation to select from available pools based on storage characteristics. Because the volume already exists, no pool selection is required during import. Therefore, the import will not fail even if the volume exists on a backend or pool that does not match the storage class specified in the PVC. -
The existing volume size is determined and set in the PVC. After the volume is imported by the storage driver, the PV is created with a ClaimRef to the PVC.
The reclaim policy is initially set to
retain
in the PV. After Kubernetes successfully binds the PVC and PV, the reclaim policy is updated to match the reclaim policy of the Storage Class. -
If the reclaim policy of the Storage Class is
delete
, the storage volume will be deleted when the PV is deleted.
By default, Astra Trident manages the PVC and renames the FlexVol and LUN on the backend. You can pass the
--no-manage
flag to import an unmanaged volume. If you use--no-manage
, Astra Trident does not perform any additional operations on the PVC or PV for the lifecycle of the objects. The storage volume is not deleted when the PV is deleted and other operations such as volume clone and volume resize are also ignored.This option is useful if you want to use Kubernetes for containerized workloads but otherwise want to manage the lifecycle of the storage volume outside of Kubernetes. -
An annotation is added to the PVC and PV that serves a dual purpose of indicating that the volume was imported and if the PVC and PV are managed. This annotation should not be modified or removed.
Import a volume
You can use tridentctl import
to import a volume.
Create the Persistent Volume Claim (PVC) file (for example,
pvc.yaml
) that will be used to create the PVC. The PVC file should includename
,namespace
,accessModes
, andstorageClassName
. Optionally, you can specifyunixPermissions
in your PVC definition.The following is an example of a minimum specification:
kind: PersistentVolumeClaim apiVersion: v1 metadata: name: my_claim namespace: my_namespace spec: accessModes: - ReadWriteOnce storageClassName: my_storage_class
Don't include additional parameters such as PV name or volume size. This can cause the import command to fail. -
Use the
tridentctl import
command to specify the name of the Astra Trident backend containing the volume and the name that uniquely identifies the volume on the storage (for example: ONTAP FlexVol, Element Volume, Cloud Volumes Service path). The-f
argument is required to specify the path to the PVC file.tridentctl import volume <backendName> <volumeName> -f <path-to-pvc-file>
Review the following volume import examples for supported drivers.
ONTAP NAS and ONTAP NAS FlexGroup
Astra Trident supports volume import using the ontap-nas
and ontap-nas-flexgroup
drivers.
Each volume created with the ontap-nas
driver is a FlexVol on the ONTAP cluster. Importing FlexVols with the ontap-nas
driver works the same. A FlexVol that already exists on an ONTAP cluster can be imported as a ontap-nas
PVC. Similarly, FlexGroup vols can be imported as ontap-nas-flexgroup
PVCs.
The following show an example of a managed volume and an unmanaged volume import.
The following example imports a volume named managed_volume
on a backend named ontap_nas
tridentctl import volume ontap_nas managed_volume -f <path-to-pvc-file> +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | pvc-bf5ad463-afbb-11e9-8d9f-5254004dfdb7 | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+
When using the --no-manage
argument, Astra Trident does not rename the volume.
The following example imports unmanaged_volume
on the ontap_nas
backend:
tridentctl import volume nas_blog unmanaged_volume -f <path-to-pvc-file> --no-manage +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | pvc-df07d542-afbc-11e9-8d9f-5254004dfdb7 | 1.0 GiB | standard | file | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | false | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+
ONTAP SAN
Astra Trident supports volume import using the ontap-san
driver. Volume import is not supported using the ontap-san-economy
driver.
Astra Trident can import ONTAP SAN FlexVols that contain a single LUN. This is consistent with the ontap-san
driver, which creates a FlexVol for each PVC and a LUN within the FlexVol. Astra Trident imports the FlexVol and associates it with the PVC definition.
For managed volumes, Astra Trident renames the FlexVol to the pvc-<uuid>
format and the LUN within the FlexVol to lun0
The following example imports the ontap-san-managed
FlexVol that is present on the ontap_san_default
backend:
tridentctl import volume ontapsan_san_default ontap-san-managed -f pvc-basic-import.yaml -n trident -d +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | pvc-d6ee4f54-4e40-4454-92fd-d00fc228d74a | 20 MiB | basic | block | cd394786-ddd5-4470-adc3-10c5ce4ca757 | online | true | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+
The following example imports unmanaged_example_volume
on the ontap_san
backend:
tridentctl import volume -n trident san_blog unmanaged_example_volume -f pvc-import.yaml --no-manage +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | pvc-1fc999c9-ce8c-459c-82e4-ed4380a4b228 | 1.0 GiB | san-blog | block | e3275890-7d80-4af6-90cc-c7a0759f555a | online | false | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+
If you have LUNS mapped to igroups that share an IQN with a Kubernetes node IQN, as shown in the following example, you will receive the error:
Element
Astra Trident supports NetApp Element software and NetApp HCI volume import using the solidfire-san
driver.
The Element driver supports duplicate volume names. However, Astra Trident returns an error if there are duplicate volume names. As a workaround, clone the volume, provide a unique volume name, and import the cloned volume. |
The following example imports an element-managed
volume on backend element_default
tridentctl import volume element_default element-managed -f pvc-basic-import.yaml -n trident -d +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | pvc-970ce1ca-2096-4ecd-8545-ac7edc24a8fe | 10 GiB | basic-element | block | d3ba047a-ea0b-43f9-9c42-e38e58301c49 | online | true | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+
Google Cloud Platform
Astra Trident supports volume import using the gcp-cvs
driver.
To import a volume backed by the NetApp Cloud Volumes Service in Google Cloud Platform, identify the volume by its volume path. The volume path is the portion of the volume's export path after the :/ . For example, if the export path is 10.0.0.1:/adroit-jolly-swift , the volume path is adroit-jolly-swift .
The following example imports a gcp-cvs
volume on backend gcpcvs_YEppr
with the volume path of adroit-jolly-swift
tridentctl import volume gcpcvs_YEppr adroit-jolly-swift -f <path-to-pvc-file> -n trident +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+ | pvc-a46ccab7-44aa-4433-94b1-e47fc8c0fa55 | 93 GiB | gcp-storage | file | e1a6e65b-299e-4568-ad05-4f0a105c888f | online | true | +------------------------------------------+--------+---------------+----------+--------------------------------------+--------+---------+
Azure NetApp Files
Astra Trident supports volume import using the azure-netapp-files
driver.
To import an Azure NetApp Files volume, identify the volume by its volume path. The volume path is the portion of the volume's export path after the :/ . For example, if the mount path is 10.0.0.2:/importvol1 , the volume path is importvol1 .
The following example imports an azure-netapp-files
volume on backend azurenetappfiles_40517
with the volume path importvol1
tridentctl import volume azurenetappfiles_40517 importvol1 -f <path-to-pvc-file> -n trident +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | NAME | SIZE | STORAGE CLASS | PROTOCOL | BACKEND UUID | STATE | MANAGED | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+ | pvc-0ee95d60-fd5c-448d-b505-b72901b3a4ab | 100 GiB | anf-storage | file | 1c01274f-d94b-44a3-98a3-04c953c9a51e | online | true | +------------------------------------------+---------+---------------+----------+--------------------------------------+--------+---------+
