Create backends with kubectl
A backend defines the relationship between Astra Trident and a storage system. It tells Astra Trident how to communicate with that storage system and how Astra Trident should provision volumes from it. After Astra Trident is installed, the next step is to create a backend. The TridentBackendConfig Custom Resource Definition (CRD) enables you to create and manage Trident backends directly through the Kubernetes interface. You can do this by using kubectl or the equivalent CLI tool for your Kubernetes distribution.
TridentBackendConfig (tbc, tbconfig, tbackendconfig) is a frontend, namespaced CRD that enables you to manage Astra Trident backends using kubectl. Kubernetes and storage admins can now create and manage backends directly through the Kubernetes CLI without requiring a dedicated command-line utility (tridentctl).
Upon the creation of a TridentBackendConfig object, the following happens:
A backend is created automatically by Astra Trident based on the configuration you provide. This is represented internally as a
TridentBackend(tbe,tridentbackend) CR. -
The
TridentBackendConfigis uniquely bound to aTridentBackendthat was created by Astra Trident.
Each TridentBackendConfig maintains a one-to-one mapping with a TridentBackend. The former is the interface provided to the user to design and configure backends; the latter is how Trident represents the actual backend object.
TridentBackend CRs are created automatically by Astra Trident. You should not modify them. If you want to make updates to backends, do this by modifying the TridentBackendConfig object.
See the following example for the format of the TridentBackendConfig CR:
kind: TridentBackendConfig
metadata:
spec:
version: 1
backendName: ontap-san-backend
storageDriverName: ontap-san
managementLIF: 10.0.0.1
dataLIF: 10.0.0.2
svm: trident_svm
credentials:
You can also take a look at the examples in the trident-installer directory for sample configurations for the desired storage platform/service.
The spec takes backend-specific configuration parameters. In this example, the backend uses the ontap-san storage driver and uses the configuration parameters that are tabulated here. For the list of configuration options for your desired storage driver, refer to the backend configuration information for your storage driver.
The spec section also includes credentials and deletionPolicy fields, which are newly introduced in the TridentBackendConfig CR:
credentials: This parameter is a required field and contains the credentials used to authenticate with the storage system/service. This is set to a user-created Kubernetes Secret. The credentials cannot be passed in plain text and will result in an error. -
deletionPolicy: This field defines what should happen when theTridentBackendConfigis deleted. It can take one of two possible values:-
delete: This results in the deletion of bothTridentBackendConfigCR and the associated backend. This is the default value. -
retain: When aTridentBackendConfigCR is deleted, the backend definition will still be present and can be managed withtridentctl. Setting the deletion policy toretainlets users downgrade to an earlier release (pre-21.04) and retain the created backends. The value for this field can be updated after aTridentBackendConfigis created.
The name of a backend is set using spec.backendName. If unspecified, the name of the backend is set to the name of the TridentBackendConfig object (metadata.name). It is recommended to explicitly set backend names using spec.backendName.
Backends that were created with tridentctl do not have an associated TridentBackendConfig object. You can choose to manage such backends with kubectl by creating a TridentBackendConfig CR. Care must be taken to specify identical config parameters (such as spec.backendName, spec.storagePrefix, spec.storageDriverName, and so on). Astra Trident will automatically bind the newly-created TridentBackendConfig with the pre-existing backend.
Steps overview
To create a new backend by using kubectl, you should do the following:
Create a Kubernetes Secret. The secret contains the credentials Astra Trident needs to communicate with the storage cluster/service.
Create a
TridentBackendConfigobject. This contains specifics about the storage cluster/service and references the secret created in the previous step.
After you create a backend, you can observe its status by using kubectl get tbc <tbc-name> -n <trident-namespace> and gather additional details.
Step 1: Create a Kubernetes Secret
Create a Secret that contains the access credentials for the backend. This is unique to each storage service/platform. Here's an example:
kubectl -n trident create -f backend-tbc-ontap-san-secret.yaml apiVersion: v1 kind: Secret metadata: name: backend-tbc-ontap-san-secret type: Opaque stringData: username: cluster-admin password: password
This table summarizes the fields that must be included in the Secret for each storage platform:
| Storage platform Secret Fields description | Secret | Fields description |
Azure NetApp Files |
clientID |
The client ID from an app registration |
Cloud Volumes Service for GCP |
private_key_id |
ID of the private key. Part of API key for GCP Service Account with CVS admin role |
private_key |
Private key. Part of API key for GCP Service Account with CVS admin role |
Element (NetApp HCI/SolidFire) |
Endpoint |
MVIP for the SolidFire cluster with tenant credentials |
ONTAP |
username |
Username to connect to the cluster/SVM. Used for credential-based authentication |
ONTAP |
password |
Password to connect to the cluster/SVM. Used for credential-based authentication |
ONTAP |
clientPrivateKey |
Base64-encoded value of client private key. Used for certificate-based authentication |
ONTAP |
chapUsername |
Inbound username. Required if useCHAP=true. For |
ONTAP |
chapInitiatorSecret |
CHAP initiator secret. Required if useCHAP=true. For |
ONTAP |
chapTargetUsername |
Target username. Required if useCHAP=true. For |
ONTAP |
chapTargetInitiatorSecret |
CHAP target initiator secret. Required if useCHAP=true. For |
The Secret created in this step will be referenced in the spec.credentials field of the TridentBackendConfig object that is created in the next step.
Step 2: Create the TridentBackendConfig CR
You are now ready to create your TridentBackendConfig CR. In this example, a backend that uses the ontap-san driver is created by using the TridentBackendConfig object shown below:
kubectl -n trident create -f backend-tbc-ontap-san.yaml
metadata:
spec:
version: 1
dataLIF: 10.0.0.2
svm: trident_svm
credentials:
Step 3: Verify the status of the TridentBackendConfig CR
Now that you created the TridentBackendConfig CR, you can verify the status. See the following example:
kubectl -n trident get tbc backend-tbc-ontap-san NAME BACKEND NAME BACKEND UUID PHASE STATUS backend-tbc-ontap-san ontap-san-backend 8d24fce7-6f60-4d4a-8ef6-bab2699e6ab8 Bound Success
A backend was successfully created and bound to the TridentBackendConfig CR.
Phase can take one of the following values:
Bound: TheTridentBackendConfigCR is associated with a backend, and that backend containsconfigRefset to theTridentBackendConfigCR's uid. -
Unbound: Represented using"". TheTridentBackendConfigobject is not bound to a backend. All newly createdTridentBackendConfigCRs are in this phase by default. After the phase changes, it cannot revert to Unbound again. -
Deleting: TheTridentBackendConfigCR'sdeletionPolicywas set to delete. When theTridentBackendConfigCR is deleted, it transitions to the Deleting state.-
If no persistent volume claims (PVCs) exist on the backend, deleting the
TridentBackendConfigwill result in Astra Trident deleting the backend as well as theTridentBackendConfigCR. -
If one or more PVCs are present on the backend, it goes to a deleting state. The
TridentBackendConfigCR subsequently also enters deleting phase. The backend andTridentBackendConfigare deleted only after all PVCs are deleted.
Lost: The backend associated with theTridentBackendConfigCR was accidentally or deliberately deleted and theTridentBackendConfigCR still has a reference to the deleted backend. TheTridentBackendConfigCR can still be deleted irrespective of thedeletionPolicyvalue. -
Unknown: Astra Trident is unable to determine the state or existence of the backend associated with theTridentBackendConfigCR. For example, if the API server is not responding or if thetridentbackends.trident.netapp.ioCRD is missing. This might require intervention.
At this stage, a backend is successfully created! There are several operations that can additionally be handled, such as backend updates and backend deletions.
(Optional) Step 4: Get more details
You can run the following command to get more information about your backend:
kubectl -n trident get tbc backend-tbc-ontap-san -o wide
NAME BACKEND NAME BACKEND UUID PHASE STATUS STORAGE DRIVER DELETION POLICY backend-tbc-ontap-san ontap-san-backend 8d24fce7-6f60-4d4a-8ef6-bab2699e6ab8 Bound Success ontap-san delete
In addition, you can also obtain a YAML/JSON dump of TridentBackendConfig.
kubectl -n trident get tbc backend-tbc-ontap-san -o yaml
metadata:
creationTimestamp: "2021-04-21T20:45:11Z"
finalizers:
- trident.netapp.io
generation: 1
namespace: trident
resourceVersion: "947143"
uid: 35b9d777-109f-43d5-8077-c74a4559d09c
spec:
credentials:
dataLIF: 10.0.0.2
svm: trident_svm
version: 1
status:
backendInfo:
backendUUID: 8d24fce7-6f60-4d4a-8ef6-bab2699e6ab8
deletionPolicy: delete
lastOperationStatus: Success
message: Backend 'ontap-san-backend' created
phase: Bound
backendInfo contains the backendName and the backendUUID of the backend that got created in response to the TridentBackendConfig CR. The lastOperationStatus field represents the status of the last operation of the TridentBackendConfig CR, which can be user-triggered (for example, user changed something in spec) or triggered by Astra Trident (for example, during Astra Trident restarts). It can either be Success or Failed. phase represents the status of the relation between the TridentBackendConfig CR and the backend. In the example above, phase has the value Bound, which means that the TridentBackendConfig CR is associated with the backend.
You can run the kubectl -n trident describe tbc <tbc-cr-name> command to get details of the event logs.
You cannot update or delete a backend which contains an associated TridentBackendConfig object using tridentctl. To understand the steps involved in switching between tridentctl and TridentBackendConfig, see here.
