Google Cloud NetApp Volumes backend configuration options and examples
Learn about NFS backend configuration options for Google Cloud NetApp Volumes and review configuration examples.
Backend configuration options
Each backend provisions volumes in a single Google Cloud region. To create volumes in other regions, you can define additional backends.
| Parameter | Description | Default |
Always 1 |
Name of the storage driver |
The value of |
(Optional) Custom name of the storage backend |
Driver name + "_" + part of API key |
Optional parameter used to specify storage pools for volume creation. |
Google Cloud account project number. The value is found on the Google Cloud portal home page. |
The Google Cloud location where Astra Trident creates GCNV volumes. When creating cross-region Kubernetes clusters, volumes created in a |
API key for the Google Cloud service account with the |
Fine-grained control of NFS mount options. |
"nfsvers=3" |
Fail provisioning if the requested volume size is above this value. |
"" (not enforced by default) |
The service level of a storage pool and its volumes. |
Google Cloud network used for GCNV volumes. |
Debug flags to use when troubleshooting. Example, |
null |
Represents a list of regions and zones that are supported by this backend. |
Volume provisioning options
You can control default volume provisioning in the defaults section of the configuration file.
The export rules for new volumes. Must be a comma-separated list of any combination of IPv4 addresses. |
"0.0.0.0/0" |
Access to the |
"false" |
Percentage of volume reserved for snapshots |
"" (accept default of 0) |
The unix permissions of new volumes (4 octal digits). |
Example configurations
The following examples show basic configurations that leave most parameters to default. This is the easiest way to define a backend.
Minimal configuration
This is the absolute minimum backend configuration. With this configuration, Astra Trident discovers all of your storage pools delegated to Google Cloud NetApp Volumes in the configured location, and places new volumes on one of those pools randomly. Because nasType is omitted, the nfs default applies and the backend will provision for NFS volumes.
This configuration is ideal when you are just getting started with Google Cloud NetApp Volumes and trying things out, but in practice you will most likely need to provide additional scoping for the volumes you provision.
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
private_key_id: 'f2cb6ed6d7cc10c453f7d3406fc700c5df0ab9ec'
private_key: |
-----BEGIN PRIVATE KEY-----
znHczZsrrtHisIsAbOguSaPIKeyAZNchRAGzlzZE4jK3bl/qp8B4Kws8zX5ojY9m
XsYg6gyxy4zq7OlwWgLwGa==
-----END PRIVATE KEY-----
kind: TridentBackendConfig
metadata:
spec:
version: 1
storageDriverName: google-cloud-netapp-volumes
projectNumber: '123455380079'
serviceLevel: premium
apiKey:
type: service_account
project_id: my-gcnv-project
client_email: myproject-prod@my-gcnv-project.iam.gserviceaccount.com
client_id: '103346282737811234567'
auth_uri: https://accounts.google.com/o/oauth2/auth
token_uri: https://oauth2.googleapis.com/token
auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs
client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/myproject-prod%40my-gcnv-project.iam.gserviceaccount.com
credentials:
Configuration with StoragePools filter
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
private_key: |
metadata:
spec:
version: 1
storagePools:
- premium-pool1-europe-west6
- premium-pool2-europe-west6
apiKey:
credentials:
Virtual pool configuration
This backend configuration defines multiple virtual pools in a single file. Virtual pools are defined in the storage section. They are useful when you have multiple storage pools supporting different service levels and you want to create storage classes in Kubernetes that represent those. Virtual pool labels are used to differentiate the pools. For instance, in the example below performance label and serviceLevel type is used to differentiate virtual pools.
You can also set some default values to be applicable to all virtual pools, and overwrite the default values for individual virtual pools. In the following example, snapshotReserve and exportRule serve as defaults for all virtual pools.
For more information, refer to Virtual pools.
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
private_key: |
metadata:
spec:
version: 1
apiKey:
credentials:
defaults:
snapshotReserve: '10'
exportRule: 10.0.0.0/24
storage:
- labels:
performance: extreme
serviceLevel: extreme
defaults:
snapshotReserve: '5'
exportRule: 0.0.0.0/0
- labels:
performance: premium
- labels:
performance: standard
serviceLevel: standard
What's next?
After you create the backend configuration file, run the following command:
kubectl create -f <backend-file>
To verify that the backend is successfully created, run the following command:
kubectl get tridentbackendconfig NAME BACKEND NAME BACKEND UUID PHASE STATUS backend-tbc-gcnv backend-tbc-gcnv b2fd1ff9-b234-477e-88fd-713913294f65 Bound Success
If the backend creation fails, something is wrong with the backend configuration. You can describe the backend using the kubectl get tridentbackendconfig <backend-name> command or view the logs to determine the cause by running the following command:
tridentctl logs
After you identify and correct the problem with the configuration file, you can delete the backend and run the create command again.
More examples
Storage class definition examples
The following is a basic StorageClass definition that refers to the backend above.
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: gcnv-nfs-sc provisioner: csi.trident.netapp.io parameters: backendType: "google-cloud-netapp-volumes"
Example definitions using the parameter.selector field:
Using parameter.selector you can specify for each StorageClass the virtual pool that is used to host a volume. The volume will have the aspects defined in the chosen pool.
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: extreme-sc provisioner: csi.trident.netapp.io parameters: selector: "performance=extreme" backendType: "google-cloud-netapp-volumes" --- apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: premium-sc provisioner: csi.trident.netapp.io parameters: selector: "performance=premium" backendType: "google-cloud-netapp-volumes" --- apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: standard-sc provisioner: csi.trident.netapp.io parameters: selector: "performance=standard" backendType: "google-cloud-netapp-volumes"
For more details on storage classes, refer to Create a storage class.
PVC definition example
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteMany
resources:
requests:
storage: 100Gi
storageClassName: gcnv-nfs-sc
To verify if the PVC is bound, run the following command:
kubectl get pvc gcnv-nfs-pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE gcnv-nfs-pvc Bound pvc-b00f2414-e229-40e6-9b16-ee03eb79a213 100Gi RWX gcnv-nfs-sc 1m
