Command-line options
Contributors netapp-aruldeepa
Trident exposes several command-line options for the Trident orchestrator. You can use these options to modify your deployment.
Logging
-debug
Enables debugging output.
-loglevel <level>
Sets the logging level (debug, info, warn, error, fatal). Defaults to info.
Kubernetes
-k8s_pod
Use this option or -k8s_api_server to enable Kubernetes support. Setting this causes Trident to use its containing pod's Kubernetes service account credentials to contact the API server. This only works when Trident runs as a pod in a Kubernetes cluster with service accounts enabled.
-k8s_api_server <insecure-address:insecure-port>
Use this option or -k8s_pod to enable Kubernetes support. When specified, Trident connects to the Kubernetes API server using the provided insecure address and port. This Enables Trident to be deployed outside of a pod; however, it only supports insecure connections to the API server. To connect securely, deploy Trident in a pod with the -k8s_pod option.
Docker
-volume_driver <name>
Driver name used when registering the Docker plugin. Defaults to netapp.
-driver_port <port-number>
Listen on this port rather than a UNIX domain socket.
-config <file>
Required; you must specify this path to a backend configuration file.
REST
-address <ip-or-host>
Specifies the address on which Trident's REST server should listen. Defaults to localhost. When listening on localhost and running inside a Kubernetes pod, the REST interface isn't directly accessible from outside the pod. Use -address "" to make the REST interface accessible from the pod IP address.
Caution Trident REST interface can be configured to listen and serve at 127.0.0.1 (for IPv4) or [::1] (for IPv6) only.
-port <port-number>
Specifies the port on which Trident's REST server should listen. Defaults to 8000.
-rest
Enables the REST interface. Defaults to true.
