Configure the Trident EKS add-on on an EKS cluster
NetApp Trident streamlines Amazon FSx for NetApp ONTAP storage management in Kubernetes to enable your developers and administrators focus on application deployment. The NetApp Trident EKS add-on includes the latest security patches, bug fixes, and is validated by AWS to work with Amazon EKS. The EKS add-on enables you to consistently ensure that your Amazon EKS clusters are secure and stable and reduce the amount of work that you need to do in order to install, configure, and update add-ons.
Prerequisites
Ensure that you have the following before configuring the Trident add-on for AWS EKS:
An Amazon EKS cluster account with permissions to work with add-ons. Refer to Amazon EKS add-ons.
AWS permissions to the AWS marketplace:
"aws-marketplace:ViewSubscriptions",
"aws-marketplace:Subscribe",
"aws-marketplace:Unsubscribe -
AMI type: Amazon Linux 2 (AL2_x86_64) or Amazon Linux 2 Arm(AL2_ARM_64)
Node type: AMD or ARM
An existing Amazon FSx for NetApp ONTAP file system
Steps
Make sure to create IAM role and AWS secret to enable EKS pods to access AWS resources. For instructions, see Create an IAM role and AWS Secret.
On your EKS Kubernetes cluster, navigate to the Add-ons tab.
Go to AWS Marketplace add-ons and choose the storage category.
Locate NetApp Trident and select the checkbox for the Trident add-on, and click Next.
Choose the desired version of the add-on.
Select the IAM role option to inherit from the node.
Configure any Optional configuration settings as required and select Next.
Follow the Add-on configuration schema and set the Configuration Values parameter on the Configuration values section to the role-arn you created on the previous step(Step 1) (value should be in the following format:
eks.amazonaws.com/role-arn: arn:aws:iam::464262061435:role/AmazonEKS_FSXN_CSI_DriverRole).
NOTE: If you select Override for the Conflict resolution method, one or more of the settings for the existing add-on can be overwritten with the Amazon EKS add-on settings. If you don't enable this option and there's a conflict with your existing settings, the operation fails. You can use the resulting error message to troubleshoot the conflict. Before selecting this option, make sure that the Amazon EKS add-on doesn't manage settings that you need to self-manage.
Select Create.
Verify that the status of the add-on is Active.
Run the following command to verify that Trident is properly installed on the cluster:
kubectl get pods -n trident
Continue the setup and configure the storage backend. For information, see Configure the Storage Backend.
Install/uninstall the Trident EKS add-on using CLI
The following example command installs the Trident EKS add-on:
eksctl create addon --name aws-ebs-csi-driver --cluster <cluster_name> --service-account-role-arn arn:aws:iam::<account_id>:role/<role_name> --force
The following command uninstalls the Trident EKS add-on:
eksctl delete addon --cluster K8s-arm --name netapp_trident-operator
