Use Trident with Amazon FSx for NetApp ONTAP
Contributors netapp-aruldeepa
Amazon FSx for NetApp ONTAP is a fully managed AWS service that enables customers to launch and run file systems powered by the NetApp ONTAP storage operating system. FSx for ONTAP enables you to leverage NetApp features, performance, and administrative capabilities you are familiar with, while taking advantage of the simplicity, agility, security, and scalability of storing data on AWS. FSx for ONTAP supports ONTAP file system features and administration APIs.
You can integrate your Amazon FSx for NetApp ONTAP file system with Trident to ensure Kubernetes clusters running in Amazon Elastic Kubernetes Service (EKS) can provision block and file persistent volumes backed by ONTAP.
A file system is the primary resource in Amazon FSx, analogous to an ONTAP cluster on premises. Within each SVM you can create one or multiple volumes, which are data containers that store the files and folders in your file system. With Amazon FSx for NetApp ONTAP will be provided as a managed file system in the cloud. The new file system type is called NetApp ONTAP.
Using Trident with Amazon FSx for NetApp ONTAP, you can ensure Kubernetes clusters running in Amazon Elastic Kubernetes Service (EKS) can provision block and file persistent volumes backed by ONTAP.
Requirements
In addition to Trident requirements, to integrate FSx for ONTAP with Trident, you need:
  • An existing Amazon EKS cluster or self-managed Kubernetes cluster with kubectl installed.
  • An existing Amazon FSx for NetApp ONTAP file system and storage virtual machine (SVM) that is reachable from your cluster's worker nodes.
  • Worker nodes that are prepared for NFS or iSCSI.
    Note Ensure you follow the node preparation steps required for Amazon Linux and Ubuntu Amazon Machine Images (AMIs) depending on your EKS AMI type.
Considerations
  • SMB volumes:
    • SMB volumes are supported using the ontap-nas driver only.
    • SMB volumes are not supported with Trident EKS add-on.
    • Trident supports SMB volumes mounted to pods running on Windows nodes only. Refer to Prepare to provision SMB volumes for details.
  • Prior to Trident 24.02, volumes created on Amazon FSx file systems that have automatic backups enabled, could not be deleted by Trident. To prevent this issue in Trident 24.02 or later, specify the fsxFilesystemID, AWS apiRegion, AWS apikey, and AWS secretKey in the backend configuration file for AWS FSx for ONTAP.
    Note If you are specifying an IAM role to Trident, then you can omit specifying the apiRegion, apiKey, and secretKey fields to Trident explicitly. For more information, refer to FSx for ONTAP configuration options and examples.
Authentication
Trident offers two modes of authentication.
  • Credential-based(Recommended): Stores credentials securely in AWS Secrets Manager. You can use the fsxadmin user for your file system or the vsadmin user configured for your SVM.
    Warning Trident expects to be run as a vsadmin SVM user or as a user with a different name that has the same role. Amazon FSx for NetApp ONTAP has an fsxadmin user that is a limited replacement of the ONTAP admin cluster user. We strongly recommend using vsadmin with Trident.
  • Certificate-based: Trident will communicate with the SVM on your FSx file system using a certificate installed on your SVM.
For details on enabling authentication, refer to the authentication for your driver type:
Tested Amazon Machine Images (AMIs)
EKS cluster supports various operating systems, but AWS has optimized certain Amazon Machine Images (AMIs) for containers and EKS. The following AMIs have been tested with Trident 24.10.
AMI
NAS
NAS-economy
SAN
SAN-economy
AL2023_x86_64_STANDARD
Yes
Yes
Yes
Yes
AL2_x86_64
Yes
Yes
Yes**
Yes**
BOTTLEROCKET_x86_64
Yes*
Yes
N/A
N/A
AL2023_ARM_64_STANDARD
Yes
Yes
Yes
Yes
AL2_ARM_64
Yes
Yes
Yes**
Yes**
BOTTLEROCKET_ARM_64
Yes*
Yes
N/A
N/A
  • *Must use "nolock" in mount options.
  • ** Unable to delete the PV without restarting the node
Note If your desired AMI is not listed here, it does not mean that it is not supported; it simply means it has not been tested. This list serves as a guide for AMIs known to work.
Tests performed with:
  • EKS version: 1.30
  • Installation Method: Helm and as an AWS add-On
  • For NAS both NFSv3 and NFSv4.1 were tested.
  • For SAN only iSCSI was tested, not NVMe-oF.
Tests performed:
  • Create: Storage Class, pvc, pod
  • Delete: pod, pvc (regular, qtree/lun – economy, NAS with AWS backup)
