Use Astra Trident with Amazon FSx for NetApp ONTAP
Amazon FSx for NetApp ONTAP is a fully managed AWS service that enables customers to launch and run file systems powered by the NetApp ONTAP storage operating system. FSx for ONTAP enables you to leverage NetApp features, performance, and administrative capabilities you are familiar with, while taking advantage of the simplicity, agility, security, and scalability of storing data on AWS. FSx for ONTAP supports ONTAP file system features and administration APIs.
Overview
A file system is the primary resource in Amazon FSx, analogous to an ONTAP cluster on premises. Within each SVM you can create one or multiple volumes, which are data containers that store the files and folders in your file system. With Amazon FSx for NetApp ONTAP, Data ONTAP will be provided as a managed file system in the cloud. The new file system type is called NetApp ONTAP.
Using Astra Trident with Amazon FSx for NetApp ONTAP, you can ensure Kubernetes clusters running in Amazon Elastic Kubernetes Service (EKS) can provision block and file persistent volumes backed by ONTAP.
Considerations
SMB volumes:
SMB volumes are supported using the
ontap-nasdriver only. -
SMB volumes are not supported with Astra Trident EKS add-on.
Astra Trident supports SMB volumes mounted to pods running on Windows nodes only.
Prior to Astra Trident 24.02, volumes created on Amazon FSx file systems that have automatic backups enabled, could not be deleted by Trident. To prevent this issue in Astra Trident 24.02 or later, specify the
fsxFilesystemID, AWSapiRegion, AWSapikey, and AWSsecretKeyin the backend configuration file for AWS FSx for ONTAP.If you are specifying an IAM role to Astra Trident, then you can omit specifying the apiRegion,apiKey, andsecretKeyfields to Astra Trident explicitly. For more information, refer to FSx for ONTAP configuration options and examples.
FSx for ONTAP driver details
You can integrate Astra Trident with Amazon FSx for NetApp ONTAP using the following drivers:
ontap-san: Each PV provisioned is a LUN within its own Amazon FSx for NetApp ONTAP volume. -
ontap-san-economy: Each PV provisioned is a LUN with a configurable number of LUNs per Amazon FSx for NetApp ONTAP volume. -
ontap-nas: Each PV provisioned is a full Amazon FSx for NetApp ONTAP volume. -
ontap-nas-economy: Each PV provisioned is a qtree, with a configurable number of qtrees per Amazon FSx for NetApp ONTAP volume. -
ontap-nas-flexgroup: Each PV provisioned is a full Amazon FSx for NetApp ONTAP FlexGroup volume.
For driver details, refer to NAS drivers and SAN drivers.
Authentication
Astra Trident offers two modes of authentication.
Certificate-based: Astra Trident will communicate with the SVM on your FSx file system using a certificate installed on your SVM.
Credential-based: You can use the
fsxadminuser for your file system or thevsadminuser configured for your SVM.Astra Trident expects to be run as a vsadminSVM user or as a user with a different name that has the same role. Amazon FSx for NetApp ONTAP has anfsxadminuser that is a limited replacement of the ONTAPadmincluster user. We strongly recommend usingvsadminwith Astra Trident.
You can update backends to move between credential-based and certificate-based methods. However, if you attempt to provide credentials and certificates, backend creation will fail. To switch to a different authentication method, you must remove the existing method from the backend configuration.
For details on enabling authentication, refer to the authentication for your driver type:
Cloud identity for EKS
Cloud identity enables Kubernetes pods to access AWS resources by authenticating as an AWS IAM role instead of by providing explicit AWS credentials.
To take advantage of cloud identity in AWS, you must have:
A Kubernetes cluster deployed using EKS
Astra Trident installed that includes the
cloudProviderspecifying"AWS"andcloudIdentityspecifying AWS IAM role.Trident operatorTo install Astra Trident using the Trident operator, edit
tridentorchestrator_cr.yamlto setcloudProviderto"AWS"and setcloudIdentityto AWS IAM role.For example:
apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident imagePullPolicy: IfNotPresent cloudProvider: "AWS" cloudIdentity: "'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/astratrident-role'"
HelmSet the values for cloud provider and cloud identity flags using the following environment variables:
export CP="AWS"
export CI="'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/astratrident-role'"The following example installs Astra Trident and sets
cloudProvidertoAWSusing the environment variable$CPand sets the 'cloudIdentity' using the environment variable$CI:helm install trident trident-operator-100.2402.0.tgz --set cloudProvider=$CP --set cloudIdentity=$CI
tridentctlSet the values for cloud provider and cloud identity flags using the following environment variables:
export CP="AWS"
export CI="'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/astratrident-role'"The following example installs Astra Trident and sets the
cloud-providerflag to$CP, andcloud-identityto$CI:tridentctl install --cloud-provider=$CP --cloud-identity="$CI" -n trident
