Prerequisites for deployment
You have to install and configure the necessary protocol prerequisites on your host before you can deploy Astra Trident.
Verify the requirements
Verify that your deployment meets all of the requirements.
Verify that you have a supported version of Docker installed. If your Docker version is out of date, install or update it.
docker --version
Verify that the protocol prerequisites are installed and configured on your host.
NFS tools
Install the NFS tools using the commands for your operating system.
sudo yum install -y nfs-utils
sudo apt-get install -y nfs-common
Reboot your worker nodes after installing the NFS tools to prevent failure when attaching volumes to containers. |
iSCSI tools
Install the iSCSI tools using the commands for your operating system.
Install the following system packages:
sudo yum install -y lsscsi iscsi-initiator-utils sg3_utils device-mapper-multipath
Check that iscsi-initiator-utils version is 6.2.0.874-2.el7 or later:
rpm -q iscsi-initiator-utils
Set scanning to manual:
sudo sed -i 's/^\(node.session.scan\).*/\1 = manual/' /etc/iscsi/iscsid.conf
Enable multipathing:
sudo mpathconf --enable --with_multipathd y --find_multipaths n
Ensure etc/multipath.confcontainsfind_multipaths nounderdefaults. -
Ensure that
iscsidandmultipathdare running:sudo systemctl enable --now iscsid multipathd
Enable and start
iscsi:sudo systemctl enable --now iscsi
sudo apt-get install -y open-iscsi lsscsi sg3-utils multipath-tools scsitools
Check that open-iscsi version is 2.0.874-5ubuntu2.10 or later (for bionic) or 2.0.874-7.1ubuntu6.1 or later (for focal):
dpkg -l open-iscsi
sudo tee /etc/multipath.conf <<-'EOF' defaults { user_friendly_names yes find_multipaths no } EOF sudo systemctl enable --now multipath-tools.service sudo service multipath-tools restartEnsure etc/multipath.confcontainsfind_multipaths nounderdefaults. -
Ensure that
open-iscsiandmultipath-toolsare enabled and running:sudo systemctl status multipath-tools sudo systemctl enable --now open-iscsi.service sudo systemctl status open-iscsi
NVMe tools
Install the NVMe tools using the commands for your operating system.
sudo yum install nvme-cli sudo yum install linux-modules-extra-$(uname -r) sudo modprobe nvme-tcp
sudo apt install nvme-cli sudo apt -y install linux-modules-extra-$(uname -r) sudo modprobe nvme-tcp
